Charging light on after alternator cjange
Old Aug 29, 2023 | 01:46 PM
fatelvis's Avatar
Default Charging light on after alternator cjange
Need guidance. I fried my alternator after driving through large rainwater pond in the middle of the road. I got a new alternator, but this pesky battery symbol keeps showing red. Multimeter and voltagemeter in dashboard tells that charging voltage is in acceptable level. What could cause this? Help.
Old Aug 29, 2023 | 02:16 PM
Parker 7's Avatar
There is a fuse X that is tied into other things that may have blown
Fuse # 10 right engine bay fuse box
This fuse provides power to make power
There is a noise suppressor on most models that you can disconnect for testing purposes
The charging voltage should be at least 13.5 volts
Old Aug 30, 2023 | 06:50 AM
fatelvis's Avatar
Ok, thanks. I'll check fuse #10 and see if solution lies there.
Old Aug 31, 2023 | 01:24 PM
clubairth1's Avatar
Community Influencer
One thing we have seen over and over is that replacement alternators cause problems. It has been recommended that to avoid all these weird problems is to rebuild your old factory original alternator. Jaguars for some reason are real picky on the electrical side!!
Old Aug 31, 2023 | 06:51 PM
Parker 7's Avatar
IN435 is the voltage regulator that the aternator fault light comes from
Brick and mortar vendor and not E - bay
# IN435 Voltage Regulator for Denso Alternators, 12 Volt,On: Asuna (1993-1993) , Geo (1990-1993) , Isuzu (1990-1993) , Jaguar (1993-1997) , Jaguar - Europe (1994-1997) (alternatorparts.com)
Bearings , brushes and such on their site
Old Aug 31, 2023 | 08:46 PM
xalty's Avatar
i forgot how the charge light works on these
x308 and later you just hook the sense wire to the dummy light wire problem solved. no more battery light when you put a chinese regulator in
Old Aug 31, 2023 | 09:23 PM
Parker 7's Avatar
The question becomes if the instrument cluster determines the acceptable alternator output voltage to not give you the light
Seems from memory that a loose alternator B + cable tie in at the starter solenoid terminal post causes the alternator light to come on
And then where exactly is the instrument voltage gauge reading / sensing from
So there are a couple of things not squared in my head
Old Sep 1, 2023 | 11:52 AM
fatelvis's Avatar
Default Charging output ok and fuse #10 solid
Charging output 14.4v and fuse #10 solid. I’ll focus on other causes then.
Old Sep 1, 2023 | 12:26 PM
Parker 7's Avatar
pic coming of terminal post on top of your starter ( attached solenoid )
Not water related but easy check
I'll be away for a couple of hours
Old Sep 2, 2023 | 11:24 AM
fatelvis's Avatar
I'll get into that as soon as it stops raining.
Old Sep 2, 2023 | 12:11 PM
Parker 7's Avatar
I may have gotten the markings on the pic someone posted with me putting on the arrows
The starter being on the rear car's left so you're looking through the intake manifold pipes
The nut is a 13 mm on a 3 inch extension from under the car
Old Sep 3, 2023 | 11:30 AM
Parker 7's Avatar
Double checking the fuse location the # 1 is closest to the large terminal post on the fuse box so you have 1 - 9 row closest to the post
The next row would start with # 10 and is a small 5 amp fuse I think tan or yellowish in color
Old Sep 5, 2023 | 06:17 AM
katar83's Avatar
It's going to be this. Seen this too many times when replacement alternator had warning light issues despite working perfectly fine. What the current replacement alternator puts out in voltage and current is basically outside of what Jag light logic allows, hence your light is now on.
Old Sep 5, 2023 | 07:59 AM
fatelvis's Avatar
And there is no other way to go around the issue? Replacing the new regulator with the old one (if not blown) cannot be done? I'd rather yank the warning light bulb off. Enough info is gain off the voltagemeter anyhow.
Old Sep 5, 2023 | 08:56 AM
xalty's Avatar
do you have ground or battery voltage at the dummy light wire? one of the two options will shut the light off guaranteed.
John-Melanie
Jan 8, 2026 02:59 PM
Spikepaga
Jul 20, 2022 03:07 PM
Mantas Petrauskas
Nov 11, 2021 06:07 PM
Johnny786
Aug 5, 2021 04:40 PM
me_laur2004
Apr 18, 2015 12:28 PM
