hi and low side Schrader valves
Old Jun 13, 2015 | 03:23 PM
prestone08's Avatar
Default hi and low side Schrader valves
hey guys I was getting the jag ready for summer time and needed to recharge the air conditioning I never noticed this before does this car not have traditional Schrader valves on the high and low sides what is this rubber ball can this be replaced the reason I ask is I apparently have a high side leak
Old Jun 13, 2015 | 03:40 PM
knightofgold's Avatar
I just fixed the same problem 2 weeks ago. The one in your picture is the low side line. The entire valve unscrews from the high side line and you have to use a wrench to take it off. The little valve itself is not replaceable, and the system will have to be completely discharged to remove it. Luckily I bought a universal part off amazon. None of the local parts stores seemed to carry the part.
Old Jun 13, 2015 | 03:47 PM
prestone08's Avatar
very interesting I kind of figured that you might have to screw off the old one but it looks factory and I didn't want to touch that seems how new lines from Jaguar are very expensive and they rarely ever come up on ebay it seemsI just don't know why in Gods name they would have put a little rubber ball there in the first place but then again every time I seem to do something on this car I go now why did they do that lol
it would be greatly appreciated if you could send me the link for where you purchased yours
Old Jun 13, 2015 | 04:22 PM
I almost forgot, the part I used was Four Seasons 59946 High Side Service Port Adapter. The parts is a whopping $6 on amazon, and fits perfectly.
Old Jun 13, 2015 | 05:02 PM
JTsmks's Avatar
Originally Posted by prestone08
very interesting I kind of figured that you might have to screw off the old one but it looks factory and I didn't want to touch that seems how new lines from Jaguar are very expensive and they rarely ever come up on ebay it seemsI just don't know why in Gods name they would have put a little rubber ball there in the first place but then again every time I seem to do something on this car I go now why did they do that lol it would be greatly appreciated if you could send me the link for where you purchased yours
There are two types of servicing valves used, Schrader and the ball spring type. It's not a "Jaguar" thing and most leaky ball/spring leaks can be corrected with a simple "poke" on the ball with an awl to re-seat or clear any debris causing it to not seat. There are also products out the to remove Schrader style ports with out replacing discharging the gas.
http://www.ryderfleetproducts.com/ai...134-p-mei-8934
https://www.google.com/shopping/prod...G5exyATOx4PoAg
Old Jun 13, 2015 | 05:14 PM
prestone08's Avatar
Thank you guys, I love this community,
I'll give it a quick poke first.
Old Jun 13, 2015 | 06:33 PM
motorcarman's Avatar
ANY GOOD auto parts store will have those valves.
I buy them in boxes of 5 from my local auto store in the tiny town of Boyd TX. (pop 975?)
The high side ones are GM common parts as well as VW and the low side is the same as Ford or VW Jettas, Beetles, etc.
bob gauff
Old Jun 22, 2015 | 09:02 PM
jc2161's Avatar
I had the same problem with my 1966 Jag XJ6 high pressure ball valve. Tried reseating the ball many times without success. OEM hose was too costly. Found a hose assembly with new valve that was a perfect fit.
ÜRO PARTSMNA7340ADA/C Refrigerant Hose$ 55.79
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
Wolfy
May 28, 2024 08:06 AM
Bowman
Sep 15, 2015 06:54 AM
avern1
Sep 8, 2015 06:25 PM
