High idle problem x300r et al.
Old Aug 2, 2013 | 11:56 PM
Adrianl's Avatar
Default High idle problem x300r et al.
I'm looking at buying a 96 XJR, but it has a few issues... large ones. The car starts and idles at close to 2500RPM. The TPS has been changed along with several other throttle components. The owner has service history, so i can check what was done, but from what I gather the parts put in were quite extensive. The research i've done on the forum, but it addresses problems with idle closer to 1500. I don't really know where to begin, though from my experience with w126 era mercedes i'm lead to believe that it's an ecu problem.
The car also has 140xxx KM, but that said it has badly worn side bolsters, worse than i've seen on 300,000+ KM bmw e34's. Are these odometers rolled back? Or could it have just been a really fat original owner, or are they just more fragile than i'd be use to in their German counterparts.
The car has the big 17in rims, but the spare is a 15, but on an original era pirelli, would this have been a normal spare for the car?
Old Aug 3, 2013 | 12:13 AM
rob20087's Avatar
Hi, sorry can't really answer your questions regarding this cars problems. If you have doubt, might be better to walk away and find one without the issues. Will be much cheaper in the long run.
Old Aug 3, 2013 | 12:16 AM
AL NZ's Avatar
Sounds like one to steer clear off
... Barge pole, etc
maybe wait for a better one to come up for sale?
good luck, let us know how you go
Old Aug 3, 2013 | 02:56 AM
Going back through your posts, I can see you've been looking for a Jaguar for over two years. With the engine and interior issues, this one sounds like it could be a lot of trouble. Better to expand your search area and travel to get an example without problems the current owner can't fix.
Old Aug 3, 2013 | 04:03 AM
AL NZ's Avatar
Default how do you diagnose leaking rear crank seal?
wrong post
Old Aug 3, 2013 | 08:47 AM
Adrianl's Avatar
It's sad to hear that you all agree with my brain, but my heart wants it... which is a terrible idea.
Old Aug 3, 2013 | 11:53 AM
motorcarman's Avatar
Simply replacing the TPS will get you all sorts of trouble.
The TPS must be configured to the ECM or sometimes you can cut slots in the sensor to set the resistance to the old TPS setting.
PDU, WDS etc. must be used to perform a throttle setup.
You might just as well do the O2 orientation and throttle pedal kickdown all at once while the computer is 'hooked-up'.
Here are some other TBSs for other causes of high idle.
bob gauff
File Type: pdf
File Type: pdf
Old Aug 4, 2013 | 10:24 PM
jvitez's Avatar
Yup, stay away! My 96 was purchased in good shape, thinking I'd need a grand or two to sort out a few things. Well, I've now spent over the purchase price in repairs. Would I have bought it if I'd have known? Nope. I could have purchased a faster newer model if I was going to pay that amount up front. Do I still like my XJR? Yes. Am I keeping it? Yes.
Heart vs mind, crystal clear: there's nothing more expensive than a cheap Jag!
Old Aug 5, 2013 | 11:36 AM
Adrianl's Avatar
I think you're all right, I'll have to pass on this one. I'll offer him a couple grand for it so I have buffer space on the gamble being fixable. If he doesn't take it, I'll wait until I can find another in the colour combination that I'm looking for.
Wolfy
May 28, 2024 08:06 AM
afterburner1
Dec 16, 2015 12:12 AM
obwoodie
Sep 3, 2015 07:45 PM
Bowman
Sep 3, 2015 03:17 PM
laserguy
Sep 3, 2015 02:02 PM
