Intermittent spark 1994 xj6 3.2
Old Mar 3, 2015 | 02:13 PM
mark rock's Avatar
Default Intermittent spark 1994 xj6 3.2
Can anyone help before I call the scrap man??
The problem seemed to arise after I changed the battery. I will start at the beginning.
My battery was starting to fade up to it wouldn't crank at all ,so I ran some jump leads off the leisure battery on my motorhome. All good up till now. I took the car for a run to put charge back into battery.
Next day tried to start but battery flat so I replaced with leisure battery as a temp fix. Car would crank but not fire.
Taking a shot in the dark I thought possibly something to do with amp output from the leisure battery, so I replaced with a correct battery from motor factors. Still no joy.
With a plug tester you can see the spark comes strong for a couple of cranks but then fades away to nothing.
I have changed the crank sensor so that's ruled out.
What I have noticed and I'm not sure if it always been there, and that was possibly the cause of flat battery is a relay clicking intermittent behind headlights(looking straight on at car left hand side 3rd relay along)
Any advice greatly appreciated..
Old Mar 3, 2015 | 05:54 PM
b1mcp's Avatar
Check the attached diagram and confirm which relay it is (Coils?). Swap with a less important one for testing purposes.
If you still have random clicking check the connections in the relay socket for power feed / ground dropping.
File Type: pdf
Old Mar 4, 2015 | 10:36 AM
mark rock's Avatar
Hi thanks for that it is the ecu controlled relay. Tried changing it but still no luck.
Old Mar 4, 2015 | 10:53 AM
b1mcp's Avatar
Mark
When you say no luck, can you explain a bit more. Does the relay still click randomly or has that gone away but still no start?
If still clicking with a replacement unit there may be an issue with the ECU. There was a post about this recently. See here...
https://www.jaguarforums.com/forum/x...-relay-137009/
ECU is easy to get to - for UK car in drivers footwell behind side trim cover on right. Check the connections for corrosion.
Old Mar 4, 2015 | 01:54 PM
mark rock's Avatar
It is again an intermittent clicking on relay , if you crank the motor it will stop clicking and there is no real time limit on when it comes back again. I tried swapping it for the fog light relay with still no start.
I will have a good read of the link you sent me shortly.
I have also noticed this evening it is very damp in car around foot wells and surrounding areas. Possibly damp in ecu.
Huge thanks for advice and I will keep you informed
Old Mar 5, 2015 | 01:41 PM
mark rock's Avatar
Quick update.
took the ecu off and wet connections, with blye buikd up trying to dry out and I will put back on at weekend
Old Mar 5, 2015 | 03:27 PM
b1mcp's Avatar
Sounds like you could be homing in on the problem. Keep us up to date.
Old Mar 6, 2015 | 12:06 PM
mark rock's Avatar
That's it closure for this post ecu dried out, put back on car all working ok.
Thanks a ton for help
Old Mar 7, 2015 | 08:20 AM
cool's Avatar
[/QUOTE]
with so much ergonomic advancement I wonder why jaguar never saw the bad position of its accelerator pedal either left or right hand drive
1100me
Jul 24, 2023 06:10 PM
Steve10
Sep 14, 2015 07:40 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
joesoap
Sep 10, 2015 01:09 AM
1100me
Sep 7, 2015 06:26 AM
