Low Oil Pressure Warning
Old Jun 23, 2015 | 02:02 PM
FrozenApple's Avatar
Default Low Oil Pressure Warning
I owned my 96xjr for almost a year now, i been fixing small problems here and there. lately my oil pressure gauge is constantly dropping to zero causing low oil pressure light to come on, it then bounces back to normal after few second. Oil is brand new, 10w30, up to level . Its becoming more constant lately comparing to before, No nasty grind or anything so i suspect it is the oil pressure itself is good but the sensor might be defective?, and according to some research there is this "fix kit" to do the gauge and stuff.
Now my question is... can i get away with replacing the sensor thats adjascent to the oil filter?
Old Jun 23, 2015 | 02:58 PM
RJ237's Avatar
Several members have replaced the sender and the problem went away.
Old Jun 23, 2015 | 03:33 PM
sender as in.. oil pump?? isnt that one in the oil pan or something? got a diagram or location ? what is the difficulties of the job?
Old Jun 23, 2015 | 06:32 PM
RJ237's Avatar
Sorry, meant sensor.
Old Jun 23, 2015 | 07:24 PM
AlbBolivar's Avatar
Yup, more than likely it is the oil pressure sender that's going bad. Cleaning it sometimes helps for a bit but for sure way is to just replace it. You will lose a bit of oil when you remove the defective one so be prepared to catch it with a pan.
Old Jun 24, 2015 | 02:40 PM
dagny747's Avatar
It is a 21mm socket and if you have a deep one that would be better. I did it with a short socket with the ratchet not pushed all the way in. Also, it took me longer to jack it up than to put it in. You can put it in by hand almost all the way since its pre-lubricated. and just tighten it down on the copper crush washer.
Part# LNA5642CA and it says Made to Jaguar specification in Italy
Old Jun 24, 2015 | 02:44 PM
dagny747's Avatar
I copied that from the thread when I replaced mine. I got it from Jaguar and it cost $28.00. If you are quick you will only lose a few drops of oil;-)
Old Jun 25, 2015 | 08:31 AM
Excellent! New sensor ordered will update as soon as i put it in
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
giandanielxk8
Sep 6, 2015 07:21 PM
AL NZ
Sep 4, 2015 08:39 PM
