Taillight problem
Old Apr 23, 2014 | 09:01 AM
mtbadger's Avatar
Default Taillight problem
I have a 96 VDP and the taillights don't come on. I have checked the fuses in the engine compartment (5A) and they are good.
Another question how do I determine what brake pads I need the parts store says there are 2 different styles.
Old Apr 25, 2014 | 02:03 PM
Benhur59's Avatar
When I had no tail lights, parking light or light for the license plate. I had to change a diode (D10) in the Lamp Control Module.
Old Apr 26, 2014 | 10:47 AM
mtbadger's Avatar
Ben I am having a hard time finding the Lamp Control Module.
Thanks for any help....
Old Apr 26, 2014 | 01:39 PM
Benhur59's Avatar
You can find it in the trunk in the plastic container, it is closest to the battery. If you Google "lamp control module jaguar xj6" you will see pictures on how it looks. The Lamp Module is easy to open and too see if the diode is broken you can compare it to the others. If it is broken you can easily replace it with a new if you can use a soldering iron.
Old Apr 28, 2014 | 09:57 AM
mtbadger's Avatar
Thanks again Ben....
Old May 2, 2014 | 05:14 PM
mtbadger's Avatar
I found the Lamp Control Module but can't find anything loose in there.
Does anybody have any other ideas before I just bite the bullet and buy another LCM....
Old May 3, 2014 | 01:46 PM
Benhur59's Avatar
The diod D10 could be broken as mine was. The diod should only let current pass in one direction and in my car it would not let current pass in any direction. I changed diod, the new diod cost about $ 2 and is much cheaper than a new module.
Old May 8, 2014 | 09:58 AM
mtbadger's Avatar
Where can I get a replacement Light Control Module?
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
