What size is the single wiperblade
Old Jan 11, 2012 | 08:14 AM
Car-Nut's Avatar
Default What size is the single wiperblade
I went into a parts store and they couldnt tell me which blade to get.
I dont have a measure with me
Feedback aprreciated...
Old Jan 11, 2012 | 08:17 AM
Canadian_XJ6's Avatar
I believe 21 inches
Old Jan 11, 2012 | 08:25 AM
Doug's Avatar
Just replaced mine the other day---22 inches
Old May 2, 2016 | 07:37 AM
DannyRobertHoward's Avatar
Hi there, I believe that there must be different wiper arm lengths as I have just replaced mine, UK model and they had to 15inches. I had previously fitted 17 inch ones and ther overlapped the chrome trim by 2inches on the near side.
Even 15inch blades have a slight overhang, but acceptable I feel. Regards, Danny.
Old May 2, 2016 | 08:17 AM
aholbro1's Avatar
21" works on all 3 of mine.
Old May 3, 2016 | 01:19 AM
drmike's Avatar
The Eurocarparts web site predicted one that fitted perfectly when I replaced mine and cost Ł3.50 delivered free.
Old May 3, 2016 | 04:55 AM
OK, I have done some research. My car is a series 3, there are different sizes for driver and passenger sides. The part number for the driver's side is DAC6135 (400mm or 15 inches). The passenger side part number is DAC 10273 (357mm or 14inches) This explains why there is a slight overhang on the nearside.
Old May 3, 2016 | 06:03 AM
caldercay's Avatar
Originally Posted by Car-Nut
I went into a parts store and they couldnt tell me which blade to get..
It's interesting you were at the parts store and they didnt, at the very least, measure it on-car, or remove it, to find a match.
I just measured the single blade on my '96 and it's 20 inches. A 21 should work.
A search at Rockauto shows the majority to be 21, with one or two at 20.
Old May 3, 2016 | 06:10 AM
caldercay's Avatar
A Series 3 (to '92) is not the x300 (94-97) platform, which is where this thread is located. It should also be noted the OP specifically asked about the "single" wiper blade.
Just wanted to clear that up for those who might be lurking, so they are not mis-informed.
Old May 22, 2016 | 05:33 PM
CBSmith's Avatar
My '97 XJ Vandan Plas is 20.5 inches, so I believe that either 20" or 21" would
be sufficient...I'd go with the 20".
(BTW, I just went out and checked with a tape.)
Poet
Feb 7, 2025 02:18 PM
hoodun
Feb 20, 2023 05:52 AM
LnrB
Oct 13, 2015 12:45 AM
Collector1
Sep 26, 2015 05:28 PM
