X300 4.0 Sovereign Engine problem (idle/running)
Old Aug 20, 2015 | 03:29 PM
Turbo_dash's Avatar
Unhappy X300 4.0 Sovereign Engine problem (idle/running)
Hello.
Sorry in advance if my english is bad. (Norwegian)
I had a issue with my Jaguar in April/May where the engine started to stall.
It have been in workshop ever since because they couldnt manage to find the faultcodes.. the engine couldnt idle at all before it stalled..
The workshop changed the sparkplugs, and cleaned the trottle body, but there was still some small misfire issue I cannot find.
I had to pay £700 for that small shitty service (Its been there for almost 4 months!)
I replaced the crank sensor today. and I replaced all coils last year.
when my car idles, it feels like it misfires on one cylinder sometimes..
does anyone know where I can begin searching?
I dont have any fault code reader. and the workshop didnt have the proper equipment.. I'm getting pretty upset about it..
Any help will be appreciated.
thanks,
Thorbjørn
Edit: and also do I have to fear that my car will stall again?
Old Aug 20, 2015 | 07:29 PM
RJ237's Avatar
Replacing the coils may not have ended the coil issue. There are a lot of poor quality coils on the market. Look at the thread below:
https://www.jaguarforums.com/forum/x...0-coils-93966/
Old Aug 20, 2015 | 07:44 PM
sparkenzap's Avatar
Do you have a check engine light? Correct name MIL, I believe!
Old Aug 21, 2015 | 08:45 AM
Turbo_dash's Avatar
I bought all six new from Britishparts.co.uk one year ago.
Are those bad ones?
Old Aug 21, 2015 | 08:58 AM
RJ237's Avatar
I don't know anything about those coils, but I have learned from the forum posts that an occasional misfire is not unusual from a coil that is failing, and it may not cause a code.
One test that has been suggested is to remove the coil cover and run the engine in a dark place, watching for arcing.
Old Aug 21, 2015 | 09:06 AM
Turbo_dash's Avatar
Thanks. Ill check that!
I have no "Check Engine" light. I checked the plugs after it were running today. and mostly every plug smelled petrol. they were not wet nor dry.. I dont know how to explain...
EDIT:
The plugs are from BOSCH, are there any plugs to recommend?
Old Aug 21, 2015 | 09:57 AM
RJ237's Avatar
The recommended plug is Champion RC12YCC or RC12YC if the first is not available. There has been extensive discussion of plug alternatives and misfire problems with other plugs. The Champions are inexpensive and appear to work well.
Old Aug 21, 2015 | 10:14 AM
Turbo_dash's Avatar
Thanks m8, appreciate your help
Old Aug 21, 2015 | 07:03 PM
Turbo_dash's Avatar
Smile
Checked now. and it was four coils that were making a light party..
2 in front. making alot of light. and the two closest to the firewall. making some light.
the two in the middle was not making any sign of lighting at all.
Old Aug 22, 2015 | 03:50 PM
theJPster's Avatar
The rule of thumb seems to be if they were were £60 or more each and they say "Made in Japan" in white letters on a black sticker, you probably got good ones. Otherwise you got bad ones.
Many reputable outlets have been selling the bad ones. I got three from SNG Barratt, but they were good enough to refund me when they died six months later. The ones currently sold by British Parts are £24, so I don't have high hopes.
Old Aug 23, 2015 | 02:29 PM
Turbo_dash's Avatar
I see on ebay that there is alot of them with lucas boxes. but are there any garuantee that they are 100% genuine. or are they cheap ones just boxed in lucas boxes to sell them like OEM ones?
rvdz
Dec 7, 2019 06:42 AM
NTL1991
XJ40 ( XJ81 )
Sep 24, 2015 09:09 PM
SkinnyLard
Aug 30, 2015 07:26 PM
SkinnyLard
Aug 29, 2015 04:24 PM
david5201u
Australia - Western
Aug 29, 2015 12:50 AM
