X300 TPS Replacement Alternatives
Old May 6, 2021 | 03:30 AM
Matto1965's Avatar
Angry X300 TPS Replacement Alternatives
Hi - new to forum in AUS. I see that there has been some discussion regarding replacement TPS for the X300 4.0l - but has anyone managed to find a decent $ alternative to the JLM12074 which sems to be out of stock in most places and mighty expesnive for what it is. Mine has the usual Ford name stamped on it but no part number. Someone said that a similar unit is the Ford Scorpio 2.9 TPS but I am not sure ? TVR Cerbera has a simlar TPS also but without getting a look at the drive (Blade D or other) its hard to tell. Does anyone know whether all TPS use a 5v base or are some different voltage ? Looking at some of the possible repalcements thay seem to be made by Intermotor (TH417) or Stark Automotive (SKTPS-0380011). Any help appreciated on an alternative. Thanks Matt
Old May 6, 2021 | 05:30 AM
countyjag's Avatar
Hi Matt,
Welcome to the forum.
If you have a browse around the various threads on the forum, you will quickly see that the TPS is a recurring problem area (in fairness, one of very few) where several forum members (including yours truly) have gone through a similar thought process to you.
The TPS units do wear out, the problem most commonly manifesting itself as a high idle speed. The OEM part does seem outlandishly expensive for something which originated in Ford's parts bin. There has been talk of a Scorpio unit working, although I have yet to see any definitive confirmation that it does. An added wrinkle is presented by the fact that the workshop manual states that there is a need to go through a throttle adaption process to make the TPS function correctly with the ECU. It has become increasingly difficult to find anyone with the equipment to do this, although some experience, including my own, suggests that fitting an OEM replacement can be successful without the adaption being performed.
All of which leaves your basic question still out there and unanswered. It strikes me that the TPS is essentially a rheostat which outputs a range of values which change based on its position. If a known working TPS can have its outputs measured (I think this data is out there already) It would seem that a match could be found, or perhaps achieved by modifying another unit. There are some packaging considerations, especially on the XJR, but where there is a will, there may be a way.
In my own case, the immediate availability of the OEM part proved too tempting, and the cost, although high, was not in the end a deterrent to achieving a "pukka" solution in this mission critical area. I have a feeling however that availability will continue to diminish, and the cost will continue to increase, so the search for the answer to your question is likely to continue.
I am sure others will have thoughts to add, as there is a large body of shared suffering on this topic!
Old May 6, 2021 | 05:54 AM
katar83's Avatar
That is a Sierra TPS and looks identical to the Jag one. I don't think anyone ever tried it, we've discussed it here a number of times and I will definitely try it myself if noone else will and when the time comes and I'll have to replace my own one.
PS
You should be able to set it up without doing a full TPS adaptation when replacing TPS, just make sure to check before removing it what's the TPS voltage with the throttle closed and make sure to fit the new one in in exactly the same position, showing exactly same TPS voltage with throttle closed. This of course can be checked under OBD live data with key in position 1. Any difference in that base voltage after TPS replacement and you'll have high idle voltage. There is enough slack in the TPS bolts to change that base voltage by 0.1V and anything over 0.02V will cause idle issues.
Old May 6, 2021 | 10:25 AM
xalty's Avatar
the sierra tps runs backwards, no go. genuine part is like 250 bucks brand new. nobody’s tried the K series throttle pot
you can milk more life out of a dying tps just by running adaptations again.
Old May 6, 2021 | 04:28 PM
Matto1965's Avatar
What OEM part did you end up using please ?
Old May 6, 2021 | 04:43 PM
xalty's Avatar
https://parts.jaguarlandroverclassic.com/jlm12074-throttle-potentiometer
Old May 7, 2021 | 07:25 AM
countyjag's Avatar
I bought mine from British parts
.https://www.britishparts.co.uk/class...-emissions-c71
Old May 7, 2021 | 05:20 PM
Matto1965's Avatar
Many thanks - they seem to be in stock also - Cheers
Katoh
Jan 21, 2025 01:20 PM
John Herbert
May 6, 2021 04:52 PM
Brewtech
Oct 2, 2019 05:03 PM
EZDriver
Mar 22, 2013 07:50 AM
EZDriver
Dec 31, 2012 12:29 PM
