2000 VDP (XJ8) throttle body number
Old Nov 22, 2013 | 03:11 AM
Lanjag's Avatar
Default 2000 VDP (XJ8) throttle body number
I have been headache and confused on throttle body part unumbers for my 2000 Jaguar VDP, I hear from someone the OEM part number is C2A1444, but I found the number XW93-9E926-AE mark on the body case, anyway, I checked on e-bay and found the two items also, when I checked on compatibility, they show "This part is not compatible with 2000 Jaguar Vanden Plas Base Sedan 4-Door 4.0L 3996CC 244Cu. In. V8 GAS DOHC Naturally Aspirated."
Old Nov 22, 2013 | 06:04 AM
jimlombardi's Avatar
Your 2000 Jaguar VDP (XJ8) has the AJ27 Engine
Part numbers for Throttle Body by Vin number range (Per Jaguar Electronic Parts Catalog - JEPC and Gaudin Jaguar website parts lookups)
now C2A1444 - Vin Range 853926 to F59525 (AJ27) without supercharger $1904 new
now C2A1445 - Vin Range F00035 to F59525 (AJ27) with supercharger $1720 new.
The model number (XW93-9E926-AE) on the throttle body (A27 engine -1999 thru 2003 XJ8 & VDP models).
ASE has a Ebay listing for rebuild service for your throttle body:
99 2000 2001 2002 Jaguar XK8 99 00 01 03 XJ8 Throttle Body Pedal and TPS Rebuild | eBay
See photo in the Ebay listing ($325) - shows the Throttle Body with the model number stamped on it. --- PART NUMBERS THIS REBUILD COVERS: Part#: XW93-9E926-AE -Other part numbers may be applicable, Please contact us to inquire if your part number is not listed) (Part must match listing image)
I had our 2001 XJ8 throttle body rebuilt by their rebuild service in August 2012 (lifetime warranty) thru their Ebay listing.
See my forum post that describes my experience with them:
https://www.jaguarforums.com/forum/x...rebuild-79462/
Here is a Photo showing the casting number (ASE calls it part number) on our 2001 XJ8 throttle body:
https://www.dropbox.com/s/ltuvtg0zif...g%20number.JPG
Jim Lombardi
Old Nov 22, 2013 | 10:37 PM
Lanjag's Avatar
Thanks a lot Jim.
Old Nov 22, 2013 | 10:42 PM
Lanjag's Avatar
Hi Jim,
I checked with my vin number is F11182, the part number still is C2A1444?
Old Nov 23, 2013 | 07:14 AM
Per Jaguar Classic Parts website - parts lookup:
Part no. C2A1444 - Throttle body parts
Part suitable for use in:
XJ Series from (V)812317 to (V)F59525 (X308)
1 + Throttle body
+ 4.0 Litre supercharged
+ Except 4.0 Litre supercharged
+ electronic
+ From VIN (853936)
+ From VIN (F00103)
C2A1444
weblink to Jaguar Classic Parts - Throttle body webpages:
http://www.jaguarclassicparts.com/uk...fuel-injection
Part no. C2A1444 | Throttle body parts from Jaguar Classic Parts UK
weblink to Gaudin Jaguar - Throttle body webpage:
2000 Jaguar Vanden Plas Parts - Direct JPLV Porsche Parts.com
Enter the part number in the
Part # / Keyword Search
C2A1444
Jim Lombardi
Old Nov 23, 2013 | 07:33 PM
motorcarman's Avatar
If the throttle assy has the Black Vacuum actuator (AJ26) then it is NOT the correct one!!!
All AJ27 throttles will work regardless of the superceded part numbers.
bob gauff
Old Nov 24, 2013 | 01:41 AM
Lanjag's Avatar
Thanks all, but I'm very confused when I checked compatibility on ebay whatever #C2A1444 or XW93-9E926-AE, they said "This part is not compatible with 2000 Jaguar Vanden Plas Base Sedan 4-Door 4.0L 3996CC 244Cu. In. V8 GAS DOHC Naturally Aspirated."
What mean is "GAS DOHC Naturally Aspirated", all AJ27 engine is GAS DOHC Naturally Aspirated?
Old Nov 24, 2013 | 02:28 AM
flay's Avatar
Thumbs up
Too much details are pushing you to a confusion. There are TB with black plastic capsule and without; yours is without. Then, on the late engine types, you have different TB if your's is supercharged or not. The number on the barrel of your TB is most important, you have AE, but also the AD will work on your (and mine ) engine. You should check for TB's corresponding with your number if you want to buy a second hand, unless you want to buy a new part. I had a chat with a guy from ASI and he explained me that both AD or AE will be the same. The best offer you can find is sending your body and have it rebuilt for 325 $ (the ebay link from Jim). On ebay UK there are new TB's at a good price, but only black capsule ones.
DOHC is double over head camshaft, practically all XJ8 and XJR engines.
Old Nov 24, 2013 | 03:32 AM
Lanjag's Avatar
Thanks a lot!
Old Nov 24, 2013 | 11:13 AM
Lanjag
Naturally Aspirated means without supercharger - Jaguar classic webpage shows parts listing 2 options as - [supercharged] versus [except supercharged (naturally aspirated - non supercharged)].
Jim Lombardi
Old Nov 24, 2013 | 10:10 PM
Lanjag's Avatar
That mean, if I looking for a used TB on ebay, it had the number XW93-9E926-AE on the barrel of TB that is I can use?
Bcrary3
Sep 12, 2021 05:41 AM
Gus
Oct 15, 2019 12:29 PM
ajacks86
Oct 12, 2017 08:51 PM
robiwhan
Sep 4, 2015 10:43 AM
