98 XJ8 Timing cover gasket
Old Jun 24, 2008 | 02:48 PM
Michigan's Avatar
Default 98 XJ8 Timing cover gasket
Apparently the oil dripping from my engine on the 1998 XJ8 is coming from the timing cover gasket. Is 6 hours labor for the garage realistic, has anyone done one at home, is it very difficult orcan patience prevail?
Thanks,
Michigan.
Old Jun 24, 2008 | 04:55 PM
hlgeorge's Avatar
Default RE: 98 XJ8 Timing cover gasket
If you are going to remove the timing chain cover, I recommend this is a good time to replace the tensioners.
Old Jun 25, 2008 | 09:07 AM
ken@britishparts.com's Avatar
The crank bolt is very tight. I mean stupid tight! It can be done at home. I too recommend looking at a chain kit.
Old Jun 26, 2008 | 07:15 PM
FactoryJaguarTech's Avatar
Yep.....chains, tensioners, guides.....the whole shabang.
Unless you remove radiator, probably will need torches to get the bolt out of damper.
With radiator out though, impact will get it out. 6 hours for timing cover removal is about right.
Good luck.
Old Jun 27, 2008 | 07:20 AM
wdonovan's Avatar
ORIGINAL: FactoryJaguarTech
.....the whole shabang.....
I'm puttin' that one back in my vocabulary.
Old Jun 27, 2008 | 09:07 AM
Those yankees have no "real" vocabulary! Come on down south and Jag Tech and I will teach you how to talk....then we can head over to LA and try to figure out what in the hell they're saying!!!
Old Jun 28, 2008 | 11:37 AM
lol
Old Jun 29, 2008 | 03:17 PM
Michigan's Avatar
Thanks for the input, please bear in mind that;
1, I'm a Brit living in Michigan
2, LA is a long way from Michigan
3, Everyone in LA think all Brits speak like Beckham and Posh
4, LA Galaxy is actually a pub team
Old Jun 30, 2008 | 07:04 PM
Again.....LOL
D.K
Dec 10, 2023 02:05 AM
Sprayall
May 30, 2021 08:13 AM
tberg
Sep 7, 2015 07:32 AM
Sprayall
Sep 3, 2015 07:49 PM
XFR_Gold
Sep 2, 2015 12:24 PM
