Is 99 V8 GM engine?
Old Feb 10, 2009 | 09:07 PM
car5car's Avatar
Default Is 99 V8 GM engine?
Some guy is selling 99 XJ8 for 2500 with seized engine. I would offer him 1500-2000 if I knew that engine parts are cheap. As far as I know GM transmission is used in Jaguars, how about engines?
Old Feb 10, 2009 | 09:47 PM
Cerberus's Avatar
Not correct on either count. ZF transmissions are used in all XJ/XK models, the -R models getting an upgraded AMG-Spec ZF tranny.
The engine is an AJV8 which is entirely Jaguar's own design. Sorry, you're really misinformed bro.
Old Feb 10, 2009 | 09:56 PM
Markus's Avatar
Default GM engine
No, actually, it is two freaking YUGO engines soldered together with a DAF infinitely variable belt transmisssion.....PUHLEEZE!
________
1999 XJR
Old Feb 10, 2009 | 09:58 PM
JagtechOhio's Avatar
What's funny is that in spite of all the GM components used on earlier models, I can't think of one GM piece I have seen anywhere on an XJ8.
Old Feb 10, 2009 | 10:14 PM
Brutal's Avatar
ya'll are cruel...........
Gm products, Ac Delco are on EVERY Jaguar I work on every day....I wear AC Delco lightly powdered latex gloves....
Old Feb 11, 2009 | 08:06 AM
car5car's Avatar
I think 86 XJS had GM transmission. I also remember GM idle speed motor.
thanks for responses, I will let guy keep his nice car!
Old Feb 11, 2009 | 09:29 AM
Car 5,
I wasn't busting your stones, Jaguar used to use transmissions (until '97), A/C compressors, EGR valves, window lift motors, all sorts of GM components back in the day...it just hadn't dawned on me that I hadn't come across any items on XJ8, until you raised the point.
Old Feb 28, 2009 | 03:15 AM
Cerberus's Avatar
Originally Posted by enigma81
Sorry.. Still misinformed.
4.0 N/A V8 - ZF 5 Speed Transmission
4.0 S/C V8 - MB (Mercedes) 5 Speed Transmission
4.2 N/A & S/C V8 - ZF 6 Speed Transmission
AJV8 Is a lot of jaguar.. but the base is really the ford/lincoln modular V8. The same basic block is used on the Lincoln LS Sedan.
And who makes the transmission for Mercedes AMG? Oh, ZF. All X308s have ZF built trannys, just different models. It's used in the E-Class AMG and the Magnum R/T.
I don't know much about the base block but if you say it's mostly Ford I'll go with that.
Old Feb 28, 2009 | 05:06 AM
heaven's Avatar
Actually no, the Lincoln, uses the Jaguar V8, the Jaguar, is a wholly Jaguar designed engine. The XJR 4.2 uses a Mercedes box, ZF yes, but a lot stronger.
Old Feb 28, 2009 | 09:20 AM
jag_genius's Avatar
exactly... about the lincoln using the jaguar V8
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
MrMellor
Sep 7, 2015 10:22 AM
OkieTim
Sep 2, 2015 12:48 PM
