ABS Module Resistor?
Old May 12, 2017 | 08:16 PM
Ivanuf's Avatar
Default ABS Module Resistor?
Hi guys, newbie here into the Jags.
I was about to do the repair of the power inputs into the ABS board, but those look ok, I looks that it melted one of the resistors (circle on picture). Anyone has repaired this? Can I do a jumper between these two points? Or do I need to send it to a repair specialist.
All other contacts seem ok,
Thanks in advance
Ivan
99 XJR
Old May 12, 2017 | 09:47 PM
Don B's Avatar
Hi Ivan,
Welcome to the Jaguar Forums. It's great to have you with us.
Regarding that missing or loose SMD component, see post number 70 in this thread:
https://www.jaguarforums.com/forum/x...ule-fix-51172/
Also, the two large pump power supply pins are not the only solder joints that can go bad. While you have the circuit board exposed, carefully check all of the joints for cold, starved or cracked solder and reflow or supplement the solder as necessary.
Please visit the https://www.jaguarforums.com/forum/n...-intro-must-5/ and post an introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old May 13, 2017 | 06:58 AM
RJ237's Avatar
If it were mine I would send it out. Also, the posts for the pumps often look okay but the solder is not making good contact because the temp. was not high enough when the board was soldered.
Old May 13, 2017 | 08:00 AM
Ivanuf's Avatar
Will do.
Is there a prefered vendor or shop that everyone from the forum uses?
Or a forum member that has good reputation fixes these units?
Old May 13, 2017 | 08:33 AM
RJ237's Avatar
Many of us have used ASI in Tennessee, but I'm not sure if they will accept a module that has been cut open. There are a couple of others mentioned on the forum so just do a search for 'module repair'. Contact them and explain that you cut the module open but haven't attempted any repairs. Link below:
http://www.autoecu.com/
Old May 13, 2017 | 08:40 AM
motorcarman's Avatar
A 1999 XJR will have TRACTION CONTROL so the part number for the ABS module will be JLM20556. (6 pipe, 9 valve)
If the module is damaged and cannot be repaired, a good used might be required for replacement.
bob
Old Apr 29, 2020 | 12:45 PM
rrosscoe's Avatar
Hi Ivanuf,
did you get your abs module repaired? i have one the same as you but my resistor is ok all the other circuit boards i have seen are different to ours
regards
rrossoe
Old Apr 29, 2020 | 08:02 PM
Jagman92's Avatar
Ivanuf,
what are the abs codes that you have stored in the module?
Old Apr 29, 2020 | 10:04 PM
Don B's Avatar
Hi Jagman92,
Welcome to the Jaguar Forums! It's great to have you with us.
Please note that rrosscoe responded to a thread that has had no activity for three years. Presumably ivanuf has resolved his ABS malfunction.
Please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
