coolant hose
Old Jun 24, 2012 | 06:07 PM
losing my mind's Avatar
Default coolant hose
where would i find the coolant hose under the fill on my 99 xjr it looks like it splits and goes three or four ways under the coolant fill and on top of trans. i cant find anything in rock auto site any info would be helpfull i have a leak where it splits looks like it goes to other side of engine thank you very much
Old Jun 24, 2012 | 07:16 PM
i think this is the lower coolant hose to the throttle body and supercharger after taking apart it goes from 1 hose to 2
Old Jun 25, 2012 | 06:34 AM
jimlombardi's Avatar
Hi
Look at this thread on cooling hoses (see post# 4):
https://www.jaguarforums.com/forum/x...fitting-65174/
The hose could be one of this bleed hose:
(#7 on top diagram and is #3 on bottom diagram from expansion tank to radiator (part# MNC4583CB) Retail price $22.35
Jim Lombardi
Old Jun 25, 2012 | 06:32 PM
thanks jim good help got it off looks like where 2 go into one is small pinhole what weird looking hose looks like an octopuss
Old Jun 25, 2012 | 08:34 PM
Hi
You said the magic words "octopuss hose assembly"
Forum member xjrguy provided the part number and these comments:
Part# MNC6733AC Hose set, to Expansion Tank and Engine - "The one labeled "hose set" is an octopus for sure."
MNC6733AE - HEATER HOSE ASSEMBLY Fits: 1998-2003 XJ8 XJR.
Forum member SirJag provided the following jpeg and comments:
"It's the Mother of All Jag Hoses. Part #MNC6733AE ----
I wish I could find this mindless rubber octopus somewhere for less than the cost of... sigh... whatever.
I think I'll wait for this one to burst. Nothing wrong with it... I was simply changing out hoses for good measure. This one will have to wait. Other things need to get done first."
Note: part4carsonline.com website appears to be discontinued.
Here is their contact information:
Phone 718 - 395 - 9398
AKNY Enterprises Corp.
P.O.Box 090066
Brooklyn NY 11209
Attn: Parts4CarsOnline.com
Here is the diagram and parts list from the JTIS21 Jaguar shop manual:
Here is the heater diagrams from the JEPC - Jaguar Electronic Parts Catalog:
Maybe there is some way to patch your existing hose instead of buying a new expensive one or maybe you should just spring for a new hose.
Gaudin Jaguar Parts.com has it (new one) listed at a discounted price of $113.75 plus shipping.
Direct JPLV Porsche Parts.com
motorcarsltd.com has a used one for $70. "HEATER HOSE 5 WAY USED XJ8 - Position: Expansion Tank to Heater Valve- SKU [USED] MNC6733AE"
Used Heater Hose - Motorcars LTD
Also on Ebay - Item number: 220900167530 $125.95 free shipping - says condition is new - mnc6733ae.
Ebays photos:
jagbits.com wants $154 for the part.
Jim Lombardi
Old Jul 3, 2012 | 01:58 PM
Smile thanks for the help
man you guys been great due to midwest storms andd no power took coupla days but she's runnin great wasnt as bad to change as it looks just remmber where things go Auto parts warehouse 126.00$ new straight to my door took a bit to get it started again for some reason but a few swearwords and threats to crush it (lol) she finally cranked over thanks again jim great info i'm learning a lot about this car and its little quirks as the wife says
Old Jul 3, 2012 | 04:57 PM
Hi
I glad you found the correct hose and great price.
The part number W0133-1656883 sold under OES tradename appears to be a nice aftermarket replacement for the factory MNC6733AE hose.
Also the free shipping is a good deal.
Jim Lombardi
Old Jun 26, 2013 | 11:24 AM
willtoliv's Avatar
How does the quick release mechanism work on the engine outlet to hose point?
Considering the amount of labour and cost of parts I think I will try to repair this leaking connection. I looked at a new hose assy at the Jag dealer and there is an "o" ring inside this connector. I'm thinking that it needs to be replaced. The condition of the hoses is very good, nice and firm, no cracks etc..Thanks
Old Jul 2, 2013 | 01:01 AM
Yala's Avatar
man i just replaced that hose on mine two weeks back and i coughed up $330 shipped and fitted at the garage i maintain the car.
Old Jul 2, 2013 | 11:32 AM
willtoliv's Avatar
How do you release the quick disconnect fitting on the block output to octopus hose?
thanks for the help.
Will
Old Jul 22, 2013 | 04:08 PM
pingj's Avatar
Will
When I replaced mine 2 years ago, I took a dremel to it just to break the connectors. I couldn't figure it out and my thought was It's toast anyway so why waste the time trying to disconnect.
Old Aug 8, 2013 | 06:13 PM
prostik's Avatar
Hi! I've just had another coolant leak (previous just fixed couple months ago with t-stat, pump, couple hoses including the one that goes through the middle of engine under pipes) Today found one more leak and coolant goes one drop in two seconds, so that is too fast :-(
According to attached picture (made it from right side of car):
Blue lines show the leaking hose.
The leak is on circled connection. Probably it's only the place where it drops and the leak is somewhere on the hose but could't check it as the engine was hot. The question - what is 'the name' of this hose and how to replace it? Do I need some special tools?
And would be appreciate if you'll give me step-by-step guide. The closest jag-mechanic is 150miles away and want to do it by myself.
Thank you!!!
XJ8 2001
p.s. If my picture doesn't explain exact location of hose - will try to make couple more pictures later...
Attached Thumbnails coolant hose-img_0335_.jpg   coolant hose-img_0336_.jpg   coolant hose-img_0337_.jpg
Old Jul 2, 2015 | 05:15 PM
BSABlueStar's Avatar
Question I read them all and STILL do not know how to release the Quick release
I have read the entire thread about replacing the Octopus Hose assembly (Part # MNC6733AE). I purchased the correct part. Problem is I STILL AM NO CLOSER TO UNDERSTANDING how to Release the Quick Release fitting!!!
It has been two days and this thing is making me crazy. Can any body take pity on a soon to be brain dead Jaguar addict?
I have taken the Octopus hose assembly to every shop and parts house in our small town NO one has seen one like it. In one shop they looked in their specialty tool program and found a special Jaguar/ Land Rover tool (PN# 3031496) I have searched now on my computer for 7 straight hours and NOT been able to confirm this tool exists let alone how it works!!
With as many people who have mentioned this Quick Fitting problem Someone Has to have learned how to release and change it..
PLEASE HELP IF YOU Can I am going NUTZ Here!
Old Jul 2, 2015 | 05:49 PM
thesameguy's Avatar
You do not need a specialty tool to disconnect the fitting - I've done it twice with no issues, though I couldn't for the life of me explain to you how. IIRC there is a knurl on the fitting which gives you a clue about how you're supposed to handle it. There is a combination of actions - you need to release a lock and then slide or turn (both?) a body to release its grip on the metal line. Maybe something like pinch the green bits and slide the black body back or something.
When I got my replacement hose it came with an extra plastic guard on the fitting which was removed and discarded, don't let that confuse you.
Old Jul 2, 2015 | 08:12 PM
Here is the PDF pages on the special Jaguar tool:
You might also try the following (provided by forum member - boomer from boston - July 30th 2011):
one might be able to take a wire coat hanger, cut a piece out, bend it into a U shape, insert that into the fitting, and pull the ends of the U apart, thus freeing the hose/tube.
Also found this photo provided by forum member pd-regan showing how to use 2 nails to remove it (his comments - just like this, with two nails):
Jim Lombardi
Old Jul 2, 2015 | 09:00 PM
motorcarman's Avatar
One side is a slide/lock connector and the other you need to rotate about 90 degrees to get the plastic 'hooks' to ride up on the plastic 'ramps' to release.
The 'slide/lock' just needs to be pushed together to get the fingers to release the grip on the connector.
I have NO IDEA what side is giving the trouble but MORE INFO would be helpful.
bob gauff
Old Sep 25, 2015 | 05:03 PM
griffplus's Avatar
Variable Restrictor Valve Dorman 902 008 | eBay
Variable Restrictor Valve Dorman 902-008
this is another issue for leaking colant
Old Sep 25, 2015 | 05:04 PM
griffplus's Avatar
Default Variable Restrictor Valve Dorman 902-008
Poet
Feb 7, 2025 02:18 PM
MrWhite
19
Jun 14, 2022 07:49 PM
vwbusbits
Oct 13, 2015 03:43 AM
Gregory Neil O'Rear
Sep 29, 2015 09:52 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
