Cowl Removal
Old Aug 17, 2014 | 11:19 PM
larney's Avatar
Default Cowl Removal
The cowl(piece between the hood and windshield) needs paint. How do I remove this? I've taken the screws out and it is now lose. It appears the windshield wiper is keeping it on along with the fluid hose. Any help to get them off would be greatly appreciated.
Also the cowl piece appears to be a dark grey in color. Is this correct? My color is Titanium Pearl if that helps.
Old Aug 18, 2014 | 05:40 AM
test point's Avatar
You do have to remove the windshield wipers and washer hoses. A tool like this one is needed:
. . . and yes, mine is dark grey but there is certainly a correct paint code for that.
Old Aug 18, 2014 | 12:14 PM
larney's Avatar
Any auto parts store?
Old Aug 18, 2014 | 03:12 PM
larney's Avatar
Does anyone know what the correct color should be? Or what is a close alternative?
Old Aug 18, 2014 | 10:51 PM
larney's Avatar
Is there a cover on the lower part of the wiper arm? In order to pull the wiper.
Old Aug 19, 2014 | 06:54 AM
rocklandjag's Avatar
yes, there is a cover over the nut that lifts up from the bottom. Be careful not to pinch or cut the washer fluid hose. Under the nut then tilt the wiper arm away from the windshield until it stays. Then you can rock the arm back and forth off of the stud. The hose disconnects right at the cowl, rotate it back and forth with pliers right at the connection.
Old Sep 30, 2019 | 12:51 AM
King Charles's Avatar
Anyone ever find out the cowl color/code ?!
Old Sep 30, 2019 | 03:07 AM
ericjansen's Avatar
Just a wild guess, but it might be the same dark grey Jaguar was using on the XK series: Dorchester Grey 342/LPD.
XK owners also use an alternative, being Duplicolor Graphite HWP102.
Might give you some leads, maybe not
vettegood
Feb 11, 2025 07:15 AM
nitrojag
Apr 18, 2018 11:22 AM
Len Apcar
Oct 9, 2013 09:12 AM
MTW
May 23, 2012 06:29 PM
Dan R
Dec 11, 2010 03:46 PM
