Dead battery, no boot access
Old Jun 2, 2024 | 11:17 AM
daves2023's Avatar
Default Dead battery, no boot access
2005 XJ8 got cancer in Dec 23, so haven't started jag since. I get around with walker so it's hard to get into back seat and take things out. Key unlocks door but under button on boot I put the key in and it turns but doesn't pop the boot.
tried under the bonnet to use the terminal at top of fuse box and a grounding nut. It did not provide enough volts to pop the boot. As I can't get under the car to look for terminals. Is there any way else to try?
Old Jun 2, 2024 | 12:47 PM
vincent661983's Avatar
wrong group. Your jag is a X350.
Old Jun 5, 2024 | 09:49 AM
03_jaaag's Avatar
idk if it’ll work on your x350 but on my x308 there is a latch inside the trunk lid where the license plate goes, its pretty difficult to get but you need to lift up with a long thin flat head though the bottom right screw hole with the tip near the middle of the boot . I had closed the trunk with the battery out.
Old Jun 5, 2024 | 11:48 AM
RandyS's Avatar
His profile says 2002 Jag x-type 2.5 4dr however,
maybe he has another Jag with that issue.
Old Jun 5, 2024 | 01:56 PM
Ken Cantor's Avatar
Originally Posted by 03_jaaag
idk if it’ll work on your x350 but on my x308 there is a latch inside the trunk lid where the license plate goes, its pretty difficult to get but you need to lift up with a long thin flat head though the bottom right screw hole. I had closed the trunk with the battery out.
I'm not positive but I think that only works with the screw locations for the larger European plates and not the standard NA ones?
Old Jun 5, 2024 | 03:02 PM
RJ237's Avatar
Connect a battery charger to the fusebox terminal and give it some time to bring the battery voltage up.
Old Jun 6, 2024 | 01:25 AM
03_jaaag's Avatar
Confirmed works on NA models mine is canadian
Old Jun 6, 2024 | 06:58 AM
Hooli's Avatar
This, or if the battery is totally dead then a jump pack set to boost.
It's how I got in mine when the battery had died & gave out about 1.1v so the charger wouldn't see it.
Old Jun 7, 2024 | 06:27 AM
daves2023's Avatar
Default Got it
I drilled a hole behind tag and saw the cable for trunk release , pulled on it and trunk popped open.
recharged battery and we are good
thanks guys
Old Jun 7, 2024 | 09:38 AM
RandyS's Avatar
I think I would repair the boot latch key mechanism immediately.
KuduZA
Sep 6, 2022 10:27 AM
Roger Kendall
XE ( X760 )
Aug 7, 2020 12:47 PM
Vectorous
May 14, 2019 10:29 AM
maltatrucker
Jul 24, 2018 02:09 PM
Forestred
Aug 1, 2011 12:02 AM
