Door Lock Actuators
Old Oct 29, 2019 | 10:43 AM
Len Apcar's Avatar
Default Door Lock Actuators
Friends,
So I need a driver door/lock actuator for a 2001 XJ8. Front pass side is about to go, too. (Lot of play in the door handle.)
I believe the driver door part no. is: GNA1081BK and the front pass food actuator is 1080DG.
Several dealer parts departments say the part is discontinued or a new one costs about $600 each.
Any recommendations?
Thanks,
LA
Old Oct 29, 2019 | 12:01 PM
avern1's Avatar
When you say lots of play in the handle, are you talking about the exterior or interior handle? Interior handle would indicate the actuator cable is failing. A fairly straight forward repair at around $100.00 per cable.
Do the doors lock and unlock correctly with the key fob?
Can you lock and unlock the drivers door with the key?
Old Oct 29, 2019 | 02:22 PM
motorcarman's Avatar
All X300 and X308 door latches should be compatible.
I routinely swap spare X308 latch assys to customers X300s.
I have abandoned X308s and most have missing door latch assys that I installed in 1995-1997 sedans.
Salvage yards are a good 'hunting-ground'.
bob
Old Oct 30, 2019 | 06:23 PM
Len Apcar's Avatar
The play is in the inside handle of the pass front door.
Keys open and close the doors normally. Key fobs also work normally
Electronic locking system is normal
Where can I find the replacement cable?
Thanks!
Old Oct 30, 2019 | 06:24 PM
Len Apcar's Avatar
thanks, motorcarman Bob. Do you have a few go-to salv yards. I use Ebay but havent used any yards in a good while.
Old Oct 30, 2019 | 07:25 PM
avern1's Avatar
Replacement is available at Jagbits. See below link.
https://www.jagbits.com/category/XJ8_BodyMechanical_20.html#/filter:model_year_2:XJ8$252F2001
Follow this link for the steps to replace it.
https://www.jaguarforums.com/forum/x...ics-faq-67357/
Old Oct 30, 2019 | 09:17 PM
Car-Part.com--Used Auto Parts Market
Look for salvage yards close if you want to get big/heavy parts but sometimes small parts are shipped cheap so distance is not a factor.
Old Nov 16, 2019 | 05:55 PM
tamsruby's Avatar
My right front door will not lock with the fob. I can lock in manually. Will replacing the inner door handle solve the problem and how do I do that. Thanks
Old Nov 16, 2019 | 07:37 PM
avern1's Avatar
First the inside handle doesn't affect the locking solenoid.
Does the door unlock with the FOB?
If it does open the door and spray liberally the lock assembly with wd-40 and spray the key hole. Then open and lose the door and lock and unlock a few times. The try locking with the FOB.
It is possible that one of the micro-switches is frozen and you can get it freed up.
Old Nov 18, 2019 | 06:06 PM
euphonium01's Avatar
Forgive me for jumping in on this, but I'm having similar problems, all of a sudden the driver's door (RHD) stopped locking/unlocking with the fob, the other 3 doors work normally using the fob. Everything works great (all 4 doors) if I use just the key manually (thread: https://www.jaguarforums.com/forum/x...k-open-225786/ )
I've changed the lock mechanism, sprayed the original with a nearly a full can of WD40, checked the micro switches, changed the door module, still won't work. There's a connector behind the left heel-board near the relay, I believe that the relay sends a signal to this connector that 'splits' the signal to all four doors, there's a small drawing of the circuit in my thread. I'm leaning towards a bad connection between that connector block and the door actuator, as the 3 others all work fine?
For tamsruby, I followed the manual around page 2,275 (right at the back) on how to change the mechanism, how to change the handles is also around the same place - 501‐14: Handles, Locks, Latches and Entry Systems. It was quite easy following that, only took about 20 minutes and the handle and mechanism were both out.
For avern1, The manual mentions various switches/actuators/lock state etc. Are all these switches etc, micro or otherwise, part of the locking assembly or should I be looking elsewhere? I did notice at least 1 micro-switch as part of the lock assembly plus wires running into blocks and into what I think was a solenoid?
Paul
GordoCatCar
May 7, 2016 02:29 AM
mikebaker3
Jan 19, 2015 06:37 PM
RobertL
Oct 28, 2014 05:00 PM
bhamilton2790
Aug 12, 2011 10:25 PM
