Driver Doors Lock Problem
Old Jan 12, 2010 | 08:52 AM
DjiXas's Avatar
Default Driver Doors Lock Problem
I have a strange problem, I was driving Jaguar and then stopped, another person tried to open driver doors from the outside, although transmission was not yet set on P and it did not open (like it should). Then I parked car, tried to open from the inside and still, won't be able to do that. All other doors unlock fine. Driver doors won't fully unlock (that metal stuff, which goes inside/outside moves only about 2-3mm and won't go all the way up).
Tried with remote control, keys, opening from inside, same... Any ideas?
It's winter here, could this be related? However, I was already driving ~50 minutes, and it first happened in a warm car, so not sure if some "ice particles" caused this, or water...
Old Jan 13, 2010 | 08:50 AM
travisjr's Avatar
Default door lock
I have had the same problem. I believe that my problem has to do with mechanical issues in the door itself and not electronic issues. I bought my 2001 xj8l used and it does have a few issues....reliability is not one of those...I've put 6,000 miles on it in the last 5 months and it has run flawlessly
Old Jan 13, 2010 | 09:14 AM
Brutal's Avatar
You can try lubing all parts, latches etc, but it is usually from the lock motor getting weak and not unlocking latch assembly. And its only avail from jaguar as a complete latch assembly
Old Jan 14, 2010 | 12:38 PM
DjiXas's Avatar
Miraculously, after driving for a few hours, it somehow opened up when I stopped and tried to open one more time.
Old Jan 28, 2010 | 10:40 AM
travisjr's Avatar
My mechanic took the mechanism apart reassembled it and lubed it and it works perfectly now. Coated 270 dollars.
Old Jan 28, 2010 | 01:20 PM
Brutal's Avatar
I HOPE HE LUBED NEVERMIND
Old Jan 28, 2010 | 01:48 PM
chupacabra's Avatar
? 270!? i could lube alot for that
Old Jan 29, 2010 | 09:28 AM
travisjr's Avatar
He did it. It works. I'm fine with it. I couldn't do it. You looking for a job in the midwest working on my Jag?
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
alpecsa
Sep 7, 2015 11:55 AM
tberg
Sep 7, 2015 07:32 AM
