drivers door....
Old Apr 3, 2016 | 05:42 PM
byjosh's Avatar
Default drivers door....
I replaced drivers door exterior door handle....now drivers window only clicks at the motor...all others work...any ideas...please and thank you
( 1998 XJ8 - added by GGG )
Old Apr 3, 2016 | 05:50 PM
I've moved your question from Jaguar Forums Feedback & Suggestion Center to X308 forum. Members here with the same model will be able to help.
Old Apr 3, 2016 | 06:09 PM
byjosh's Avatar
Thx.....sorry
Old Apr 3, 2016 | 07:40 PM
Addicted2boost's Avatar
Yes, what you need to do is take the door panel back off and disconnect the door ECU and then reconnect it back up. Chances are you might've nudged the ECU a bit and that was enough to have a loose connection from the plug. I've done it myself.
Old Apr 3, 2016 | 08:19 PM
byjosh's Avatar
Is the ECU the main door harness on backside of door panel?
Old Apr 3, 2016 | 09:01 PM
ericjansen's Avatar
Don't forget to do a battery 'hard reset' after that, will not work without that, and strange things and mix up will happen.
Old Apr 5, 2016 | 06:26 AM
The ECU is located inside the door itself. Big grey box. Disconnect and reconnect then do the hard reset as suggested.
Old Apr 5, 2016 | 08:05 AM
byjosh's Avatar
Thanks everyone . ....it worked great ! !!
Halex
General Tech Help
Apr 9, 2016 09:31 AM
shimonek
Apr 4, 2016 09:49 PM
Travis O'Gallagher
Apr 3, 2016 02:49 PM
rsq911
Apr 1, 2016 11:23 AM
