Fuel pump brand recommendations
Old Aug 4, 2025 | 09:44 AM
pcolapacker's Avatar
Default Fuel pump brand recommendations
Title pretty much says it all. I have tank out for bad fuel level sender and going to replace both pumps proactively. Car sat for five years before I bought. Numerous available brands. From experience any to go with and any to stay away from.
Old Aug 4, 2025 | 10:25 AM
Highhorse's Avatar
Delphi & Denso ...the rest are all Chinese. Not that these aren't, but they have QA supervision.
Old Aug 4, 2025 | 11:26 AM
Addicted2boost's Avatar
Denso, always.
Old Aug 4, 2025 | 01:23 PM
Originally Posted by Addicted2boost
Denso, always.
But URO is so much cheaper
Old Aug 4, 2025 | 05:38 PM
RandyS's Avatar
Until....it fails too soon and you replace it again. However...to be truthful, I have
found that sometimes....the cheap parts last just as long.
Old Aug 4, 2025 | 07:08 PM
motorcarman's Avatar
The URO pump is a DIRECT PLUG-IN, no harness modification.
I have had several URO pumps in a few of my six running X308/X100 cars for some as long as 10 years now.
Like the brand or not, they are the ONLY ones making SOME replacement parts and sometimes you have to get them or find used!!!!!!!!!!!!!(Jaguar is NLA on hundreds/thousands of parts)
The pumps are available from other manufacturers but I have personally not had an issue with the URO pumps.
Some parts are questionable but the pumps do not seem to be one of them, at least in the past when I purchased them.
Old Aug 5, 2025 | 08:48 AM
Default Pumps out
Old Aug 5, 2025 | 11:00 AM
Went with Delphi off RockAuto for $74 each. The Denso is not a lot more at RockAuto, Parts Geek, and Summit but noted as compatible for only 98 and 99. Confusing because all three suppliers list the Delphi for 98-03.
Old Aug 7, 2025 | 09:27 PM
[img alt="Old URO right, new Delphi left
Bottoms different "]https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_2166_33943b07f26271e3a7743b224fe0c3138203b2bf. jpeg[/img]
Old URO right, new Delphi left Bottoms different
[img alt="Bottom pads
Right - original that exactly fits URO
Center - original with trimmed rubber to fit Delphi
Left - Delpi supplied, way to thick to fit in holder and too big"]https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/2000x1504/img_2163_9c05856f3ec9f0e6ef8b782d16d44b741a343592. jpeg[/img]
Bottom pads Right - original that exactly fits URO Center - original with trimmed rubber to fit Delphi Left - Delpi supplied, way to thick to fit in holder and too big
Additional connector to mate with Jag wiring
Old Aug 7, 2025 | 09:30 PM
Pics did not load in last post.
Old Aug 8, 2025 | 02:19 AM
xalty's Avatar
that pump doesn’t have a barb, it’s gonna blow off on you been there done that. the only barbless fuel pumps you can use are ones with plastic nipples
Old Aug 8, 2025 | 02:27 AM
Vauxi's Avatar
I kinda hijack the topic. But can anyone measure the diameter of the pump ? I'm planning to use only one aftermarket pump to take care of both of the oe pumps.
Nevermind. Rockauto listed them.
Old Aug 8, 2025 | 07:56 AM
Big thanks for catching that. Don’t want to have to drop tank again. Looked at pics of pumps on RockAuto. Only URO has barb. Either sending pumps back or going to use some gasoline resistant glue in addition to clamp.
Zalastar
Feb 14, 2023 12:42 AM
05strSATX
Sep 7, 2021 02:48 PM
twocross
Jul 4, 2020 05:36 PM
louvit
May 15, 2013 11:03 AM
Jerry the Jaguar
Aug 31, 2010 03:18 PM
