Glove compartment door
Old Dec 6, 2015 | 09:50 PM
Presence's Avatar
Default Glove compartment door
The door to my glove compartment closes, but not enough. I have to give it an extra push to get it to go in better, otherwise the light doesn't go out. What do I need to look at to fix this?
Old Dec 6, 2015 | 11:16 PM
King Charles's Avatar
I'd spray it with WD-40 or some similar lubricant as well as check all hinge & mounting screws & handle to make sure they are tight & flush.
Old Dec 7, 2015 | 10:34 AM
Jhartz's Avatar
empty it first; then check to make sure the side tabs are not interfering with the closing.
Old Dec 9, 2015 | 09:36 AM
kp98xj8's Avatar
Default Latches
Make sure both latches on the side are sticking out before shutting it. See post.
https://www.jaguarforums.com/forum/x...sy-fix-140587/
Old Dec 9, 2015 | 03:42 PM
convincor's Avatar
adjust the catch on the dash side. Torx head screw.
It's right near the light.
Old Dec 9, 2015 | 03:53 PM
buckshaw's Avatar
Clearly, your Grey Poupon jar should be stowed horizontally, not vertically. Refer to the Owners Guide, Smug section. Oh, and keep a stiff upper lip.
Old Feb 15, 2016 | 04:54 PM
Presence's Avatar
That is indeed the problem. WD-40?
Old Feb 15, 2016 | 06:28 PM
kp98xj8's Avatar
A dry lube might be better, try powdered graphite. Then use it to give your locks some attention.
brittunculus
Nov 27, 2023 12:34 PM
Naso--Lituratus
Jan 31, 2017 06:01 AM
Ryandva
Dec 19, 2015 09:51 AM
Platinum XJR
Dec 6, 2015 02:39 PM
Beagle
Dec 4, 2015 02:27 PM
