Having to use it daily
Old Dec 26, 2020 | 04:55 AM
Me9's Avatar
Me9
Default Having to use it daily
I'm having to use the Jag daily and it's killing me at 17ish to the gal, as I wrote in another post about a duff 02 sensor, if that is what's causing this then fair enough but using it daily is hellish.
I also have a Golf Mk4 tdi but can't use it just now, so the quicker I can get an 02 sensor in this behemoth the better. I know it's not going to be night/day mpg being a 3.2 v8 but it will hopefully help.
Then again maybe if I get the Golf running it won't use the Jag again.
Thinking about it, I don't need a 3.2 v8 to run about it, yes I wanted back to an auto but this thing, nope.
Old Dec 26, 2020 | 10:25 AM
Don B's Avatar
Replacing the O2S should help. Other common cause of reduced fuel economy is a stuck-open engine coolant thermostat or a failed engine coolant temperature sensor. If the engine does not reach full operating temperature, or if the ECTS is misreporting the coolant as cold, the engine control module will continue to apply cold-start fuel enrichment even with the engine hot, leading to rich running and poor economy. If your scan tool can display Live Data, look at the coolant temperature parameter to see if it seems colder than it should.
Cheers,
Don
Old Dec 26, 2020 | 11:24 AM
Me9's Avatar
Me9
Thanks for the reply.... the engine temp is fine it sits half way up no problem and doesn't move. I'm tempted to put a new one in but really trying to get my head round the fact of having such a big car/ engine to do what I do.
Old Dec 26, 2020 | 12:50 PM
Don B's Avatar
The temperature gauge in the instrument cluster is notoriously unrepresentative of actual temperature and cannot be relied upon. The needle will sit at the "Normal" line at temperatures between about 180F and 239F, so you cannot judge your coolant temp by that gauge. A scan tool with Live Data capability is your friend.
Our member WhiteXKR has designed a kit called RealGauge that converts the "dumb" temperature gauge to show actual relative temperature. Check it out at thejagwrangler.com
Cheers,
Don
Old Dec 26, 2020 | 01:40 PM
Me9's Avatar
Me9
Again thanks for the reply
I'll have a look at that site, I'm used to having a temp gauge though but also know they are not always accurate.
But as I said at the start, I really am thinking hard if I can justify having a 3.2 v8 tank to ideally use a daily, I know nobody here can make that decision though.
Old Dec 27, 2020 | 03:56 AM
Me9's Avatar
Me9
I'll give it a miss as I don't think I'll have this for long, Jags aren't what they're cracked up to be in my opinion
Old Dec 27, 2020 | 04:01 AM
Me9's Avatar
Me9
Old Dec 27, 2020 | 10:15 AM
Don B's Avatar
I work on a wide variety of older luxury performance vehicles and can tell you that Jaguars are often just as reliable, and in many ways superior, to contemporaneous BMWs, Mercedes, Volvos, Audis and other competitors.
The most regrettable issue that too many of these cars suffer from is negligence by owners who don't bother to resolve simple issues like replacing faulty oxygen sensors and thermostats and other basic maintenance items, which leads to problems that are more serious and expensive, and sometimes catastrophic.
Any car you own will need an oxygen sensor or thermostat replaced from time to time.
Cheers,
Don
Old Dec 27, 2020 | 01:35 PM
Me9's Avatar
Me9
Yes you're absolutely right and I have fixed and replaced many parts of various cars like yourself and others through the years. What I simply meant was that I am trying to justify having a 3.2 v8 as a daily, i think it's just stupid especially as I only do about 10 miles a day and that's not everyday.
Sure it's nice to travel in comfort ect but it's not the be all ect, not to me. I am going to have to think about things.
cheers
Old Dec 29, 2020 | 07:13 PM
Carnival Kid's Avatar
To buy a 20 year old Jaguar as a daily driver is, as you say, "just stupid", especially in the UK with the high gas/petrol prices. A Jaguar the age of any X308 will, like any 20+-year-old automobile, be in need of some devotion and care to maintain it in a manner it was designed to effect.
When new it may have served well as a daily driver for those affluent enough to afford to have purchased it new, but I think even then most buyers used it as a luxury item rather than a commuter vehicle.
I think if you try to continue to use your vehicle as a daily driver you will find that the cost necessary on such a vehicle to simply bring it up to "daily driver" status, and the on-going cost in gasoline/petrol expenses will prove to be imprudent. Maybe it would be better to sell the vehicle to someone who wants to preserve the Jaguar as a "Sunday driver", and you maybe buy an older Fiat Panda, or a Ford Fiesta, or Vauxhall Astra as a commuter car?
Old Dec 30, 2020 | 03:59 AM
Me9's Avatar
Me9
While you are right you obviously didn't see/ read the fact that I have a Golf tdi too.
Old Dec 30, 2020 | 05:20 AM
I did see that you stated that you own a VW Golf Mk4, you said you couldn't use it at this time. Therefore the subject returns to whether or not your current usable vehicle, the Jaguar, is a suitable daily driver, and I think the answer to that is that it is not if it is to be a long term duty.
I guess the plan should be to get the Golf fixed asap?
Old Dec 30, 2020 | 06:28 AM
Me9's Avatar
Me9
I also think I haven't said things properly too, I do like the XJ8 and have been using it and yes I would love to keep it as a second car but will need to think about that.
I also realise anything at that age will probably need some tlc unless it has been well cared for and mine hasn't, well it kind of has but not fully.
I'll see where things go from here, I also got the Golf running again and will use it as you also rightly say regarding the price of fuel in the UK, it's a rip off compared to other countries.
I would like to keep the Jag as piece of British heritage.
Old Dec 31, 2020 | 11:55 AM
Addicted2boost's Avatar
This I can assure you... your jag much appreciated being driven daily while the Golf was down. Jags don’t like to sit much. If you got the Golf running, kudos to you. Be appreciative that it ran for you while while you fixed the VW. I know petrol is very expensive across the pond and you probably already know about the alternative fuel conversions as well. Just remember, there’s nothing more expensive than a cheap Jaguar.
Old Dec 31, 2020 | 12:02 PM
Very well said!
Old Dec 31, 2020 | 05:52 PM
King Charles's Avatar
Mine's been my daily for some time now, I keep it in sport mode & disregard the MPG read outs lol.
Old Dec 31, 2020 | 07:20 PM
Me9's Avatar
Me9
You obviously have more cash at your disposal than me good for you.
Me9
Dec 31, 2020 02:57 AM
Ludovic Card
Jul 2, 2016 09:17 AM
ThyJones
Jan 8, 2013 01:54 PM
Simprof
Apr 29, 2011 11:16 AM
