help engine questions
Old Dec 3, 2014 | 06:09 PM
batson58's Avatar
Default help engine questions
2000 xj8 4.0 wires burnt to crank sensor now engine is dragging like a bad starter or week battery. have replaced wires to crank sensor , do I replace engine , or is there something else I can do, Thanks for any help or input
Old Dec 3, 2014 | 06:17 PM
RJ237's Avatar
It's a little early to say you need to replace the engine. Find someone with a code reader and report the codes here so that we may possibly have an idea what is going on.
Old Dec 3, 2014 | 06:28 PM
batson58's Avatar
have a reader, will read tomorrow thanks
Old Dec 3, 2014 | 11:40 PM
sparkenzap's Avatar
"wires burnt to crank sensor"= Do you really mean the wires were burned to the crank position sensor on the bottom of the bell housing? If so, what burning road were you driving on? I would say it is just short of impossible to imagine a reluctance sensor wire harness having enough current to burn the wires. Not disputing what you say (exactly) BUT something seems amiss here.
Old Dec 4, 2014 | 03:20 AM
JagV8's Avatar
+1 more detail needed
The sensor doesn't affect the mechanical lumps so engine should be OK I think.
Old Dec 4, 2014 | 04:10 AM
andrew lowe's Avatar
Apparently, it was the wires behind the power steering pump that caught fire, when his son was driving.
Have you checked the earths and the power connector at the false bulk head ?
But am also a +1 on getting the codes pulled and post them up.
Otherwise it is all just guess work
Old Dec 5, 2014 | 04:51 PM
batson58's Avatar
Default codes
p0335 crank sensor, p1384 vvt solenoid a malfunction, p 1396 glow plug monitor fault ( bank 2 ) thanks to all for any help
Old Dec 5, 2014 | 05:04 PM
batson58's Avatar
you are correct some fluid dripped on wire and it caught fire, my son put fire out before anything else was damaged
Old Mar 22, 2015 | 04:07 PM
batson58's Avatar
Default problem solved
the engine cracked thus no compression , shop says new motor, have found some doner cars
Old Mar 23, 2015 | 05:53 AM
RJ237's Avatar
That does not make much sense. No or low compression on all cylinders? That would be due to cylinder wash, which occurs when continuously cranking an engine that doesn't start.
Is your mechanic a Jag specialist, or at least a foreign car specialist? Please ask for the compression figures and post here.
Old Mar 23, 2015 | 10:00 AM
JimmyL's Avatar
Engine cracked ? Glow plug monitor fault ? Where are the glow plugs ? I'm just a little curious about what happened. Oh well.
Old Mar 23, 2015 | 10:05 AM
Mikey's Avatar
The two statements disagree.
Your engine doesn't have glow plugs........
I think you need a new mechanic.
Old Mar 24, 2015 | 07:26 PM
sparkenzap's Avatar
"I think you need a new mechanic. "
++ on that. Either you have misunderstood him, or reported info from other places as coming from the wrench, or he is incompetent as hell!
It is highly unlikely a new engine is needed. Moreso a new engine would not fix any of the problems you described.
D.K
Dec 10, 2023 02:05 AM
way2far
Aug 31, 2022 09:26 AM
KarimPA
Sep 3, 2015 07:32 PM
OkieTim
Sep 2, 2015 12:48 PM
TC Johnson
Sep 2, 2015 09:30 AM
