help I mixed green steering wheel fluid with red fluid.
Old Mar 17, 2019 | 01:23 PM
RA110623's Avatar
Banned
Default help I mixed green steering wheel fluid with red fluid.
I checked the power steering wheel fluid it was low so I bought power steering fluid the when added the fluid I figured out its green I think I put around 200 ml of the green fluid. now I hear crisp sound when I turn the steering wheel to max direction
what to do? and what could happen?
Old Mar 17, 2019 | 01:46 PM
xjack's Avatar
Oh boy, you are very active lately.
If the green fluid you added was intended for PS than perhaps your full lock grinding have nothing to do with the addition. In any case drain and refill should do.
Old Mar 17, 2019 | 02:45 PM
RA110623's Avatar
Banned
it's Prestone power sterstee fluid. should I drain all the fluid now?
Old Mar 17, 2019 | 03:06 PM
xjack's Avatar
Well, prestone manufactures various fluids, unless you specify exactly name of yours it going to be hit and miss. Does yours state anywhere on the bottle Dexron III ATF ?
Old Mar 17, 2019 | 03:31 PM
RA110623's Avatar
Banned
here's the product
Old Mar 17, 2019 | 03:59 PM
xjack's Avatar
I'm unable to find any conclusive information about what prestone puts in there, moreso they manufacture few ps fluids branded as american/eu/asian cars etc.
Unless someone else here have an experience with those lubes and can confirm i would drain and refill with Dexron III ATF
Old Mar 17, 2019 | 04:50 PM
RA110623's Avatar
Banned
what a mistake . hope someone have an experience with issue inlight me .
thank you for help .
Old Mar 17, 2019 | 04:55 PM
xjack's Avatar
Not your fault, they brand it as PS fluid but wont specify the details + having five different fluids without details for the same application makes a mental mess, i don't think it did any damage to the system, PS is very forgiving.
Old Mar 17, 2019 | 05:06 PM
RA110623's Avatar
Banned
i hope nothing goes wrong with the ps system. will flush it soon and add ATF 3 .
weeks ago I saw ATF iii fluid but it had gear picture on it I was confused I thought it's only for transmission then bought the one with steering wheel picture but didn't know it's green.
thanks 👍
Old Mar 17, 2019 | 05:22 PM
Dutchy's Avatar
I believe different brands and or colors may behave differently from each other
in relation to temp and physical change
same as cross mixing of engine oil's
for the sake of a few dollars and a painful time lost
peace of mine I'd change it.
I am sure it has done no damage
XJLFTW
Nov 27, 2015 05:03 AM
Plum
Jan 28, 2011 02:38 PM
VMV
Dec 20, 2009 12:00 PM
phaelax
Apr 1, 2009 10:21 PM
toutlnone
Feb 25, 2009 11:00 AM
