How do I unlock the gas cap on my '02 VDP?!
So far the only way that I have figured out is to put the key in the drivers door and and turn clockwise (that is ridiculous, I know, but it seems the gas cap is always locked otherwise)
Definitely not the case for me, I don't remember if my last gas-up I pressed the dashboard unlock button or if I opened the driver's door to unlocks all doors, but one of those definitely did not open the gas cap (need more experimenting to confirm which)
I got tired of playing games with mine and disabled the lock feature on the fuel door by removing the plastic lock tab on the bottom of the door.
It's a useless feature anyhow. If you saw the contraption down in the tank that prevents fuel spill out of the filler in the event of a rollover, you'd agree that siphoning fuel is unlikely. Not impossible but very unlikely.
I guess I may have to worry about someone adding sugar to the tank, but I try not to have to many enemies anyhow.
Ken
Ken
Yep. One time at the pump it would not open. Problem was solved with a screwdriver. You'll be shocked at how little security the locking lid offers. Heck I think I could have popped it with my bare hands if I wanted to bad enough.
I wish that worked for me but it didn't. I tried opening the cover in the left rear trunk and saw the switch but could not manually move the locking mechanism. also when I put the key into the drivers lock, turned it clockwise, all four windows went down. I had changed the fob battery but no change and neither fob appears to lock or unlock the doors.
aholbro1
Dec 29, 2024 06:46 PM
