How to remove radiators? 2000 XJR
Old Jan 28, 2014 | 12:49 PM
WaterDragon's Avatar
Default How to remove radiators? 2000 XJR
I'm going to replace the primary tensioners and rails.
My question is what is the procedure to remove the radiators?
I'm thinking ( I know what this often leads to....) that removing the radiators will give much better general access and will give more room to to remove the crank pulley.
Old Jan 28, 2014 | 02:50 PM
motorcarman's Avatar
Just pull the fan assy.
Put a piece of sheet metal or thin plywood to protect the rad fins.
bob gauff
Old Jan 28, 2014 | 02:59 PM
OOOOOOOOOoooooo, GOOD answer.
Thank you!
dsnyder586
Dec 29, 2024 07:39 PM
Bcrary3
Sep 12, 2021 05:41 AM
philwarner
Sep 6, 2015 11:10 PM
obwoodie
Sep 3, 2015 07:45 PM
