I screwed it up
Old Apr 1, 2019 | 08:28 AM
jrb53's Avatar
Angry I screwed it up
2002 x308 .I screwed it up, had one of the bulbs go out in the dash cluster, so removed the instrument cluster changed the offending bulb started putting it back in locked in yellow multi plug put black multi plug back then had to go and do something, came back later to finish off reattached battery came up with bus can fault I had forgotten to lock black multi plug in place so locked in place now my seat and steering column will not adjust automatically they both work manually checked fuses ok now I am stuck any advice please thanks jrb53
Old Apr 1, 2019 | 09:02 AM
RJ237's Avatar
You should never work on the electrical system without first disconnecting the battery. Try doing a hard reset: Remove negative cable from battery and touch to the positive post for a few seconds. Then reconnect and turn ignition key on and wait about a minute to allow the ECU to communicate with the other modules before starting.
Old Apr 1, 2019 | 09:15 AM
AJ16er's Avatar
Originally Posted by RJ237
You should never work on the electrical system without first disconnecting the battery. .
This should be a sticky with bold capital letters. Second time I have read that somebody had problems after failing to do this. If the X308 is like my 97 XJ6 then the battery is easily accessible in the trunk. Some cars have them underneath a seat. We're lucky here.
Old Apr 2, 2019 | 07:57 AM
jrb53's Avatar
I did disconnect battery first but forgot to lock in black multi plug. Tried hard reset same problem will do it again whiles waiting for a minuet thanks
Old Apr 5, 2019 | 06:16 AM
AJ16er's Avatar
Any luck?
Old Apr 5, 2019 | 08:03 AM
jrb53's Avatar
No still have to move seat and steering manually I am now stuck as to what module controls movement of both steering and seats. drivers door or seat or could it be the programming on drivers door ????? any help would be appreciated thanks jrb53
Old Apr 5, 2019 | 09:26 AM
M. Stojanovic's Avatar
Try with first manually positioning everything (seat, steering and the side mirror) as you like them to be and store the setting into Memory 1 on the drivers door switch console. Then (for comparison) make another different positioning of everything and store in Memory 2. Then press Memory 1 to see if everything will move to your first settings. After that, see if your automatic positioning works.
Old Apr 5, 2019 | 10:18 AM
Brutal's Avatar
May just be conicidence cause seems like nothing you have done that would cause a failure. Failures happen and they can easily be coincidence at the time you did the repair. Try being a mechanic and talking to someone about this issue
Old Apr 6, 2019 | 08:58 AM
jrb53's Avatar
I have tried all of that off the junk yard today will pick up a few things, even if I don't use them now they will be in my stock cabinet for later use as having 4 xj8's I always need something my mechanic is on vacation so will post again with findings thanks jrb53
Old Apr 6, 2019 | 09:35 AM
motorcarman's Avatar
Plenty of info on the operation and diagnosis of the memory systems.
I uploaded hundreds of TSBs to this site years ago. (that nobody reads)
Here are a few.
bob
File Type: pdf
File Type: pdf
Old Apr 7, 2019 | 09:58 AM
jrb53's Avatar
Decided to take door panel off and check everything again of course I broke two of the panel studs. I found the cause of all my problems!!! My 18 year old daughter had been driving my 02 while I was in Florida for a couple of weeks instead of the 2000 that I let her drive when she has problems with her Mini Cooper. anyway she took the 02 because the 2000 needed gas she had shut the auto function off on steering column which I never looked at as I always leave it on because she did not want to reprogram the seat so I would know she had driven it..
so I apologize for wasting your time. So moral of story is look at the obvious first which I did not do and save yourself a lot of grief thank you jrb53
XJ8Johnny
Dec 18, 2009 04:39 PM
panza
XJ40 ( XJ81 )
Jun 27, 2009 04:21 PM
jaguarevan
Feb 12, 2009 12:24 PM
frombenz2jag
Jan 10, 2008 08:08 AM
