Issue with part near throttle body
Old Oct 25, 2025 | 06:35 PM
franky90's Avatar
Exclamation Issue with part near throttle body
Seems this part is loose or broken. It came off while I was driving and noticed it when I had looked under the hood.
Just looking to get suggestions or help with this, if there's a part number or something I can buy to replace it.
Hose off, broken.
Hose off, broken.
Hose on, it's loose. I can pull it out, I know you're supposed to be able to press the sides to pull it out, but that's not needed.
Old Oct 25, 2025 | 06:58 PM
franky90's Avatar
Would love to get some DIY options, as I'm not particularly looking to spend a lot of money, unless I really have to.
Old Oct 26, 2025 | 03:54 AM
xjack's Avatar
Remove o-ring, clean it thoroughly, and glue it in place with oil resistant semi elastic epoxy type glue, next time you will need to take things apart you will disconnect hose at valve cover
Other option is getting the elbow from junkyard
Obviously don't drive like that too much cause you have a massive air leak now and car is running lean
Old Oct 26, 2025 | 04:53 AM
BringBackFord's Avatar
That air duct is not expensive at all. Neither is the full breather hose.
In this case I say buy new one.
Old Oct 26, 2025 | 09:16 AM
Sean B's Avatar
+1 the part no# NCA3951CB
Old Oct 26, 2025 | 11:22 AM
RandyS's Avatar
Planned obsolescence is surely apparent with that part.
Old Oct 26, 2025 | 06:13 PM
franky90's Avatar
Breather hose is fine from what I can tell. I'm looking to replace the part it goes into, NNC3555BA is the correct part number I'd need for a 2002 XJ8? Just want to be 100% before I buy.
Old Oct 27, 2025 | 05:32 PM
Sean B's Avatar
I would be more concerned about the oil.
You can remove and clean the inlet snorkel with brake cleaner, then look up the process of cleaning the part load and full load breathers - the part you want to replace can be tidied up with a scotch pad and refitted.
There maybe a possible EGR issue - black gunk suggests possible blow-by? A good inspection of all induction including the egr assembly is something you might want to look into.
Old Oct 28, 2025 | 12:04 PM
RandyS's Avatar
There are multiple inexpensive ways to repair that connection. You really don't need
any expensive parts requiring shipping. Lowes and Home Depot have a variety of fittings
that could be used.
scottatl
Oct 14, 2024 11:07 AM
Oliver94
Feb 19, 2024 03:04 AM
earny
Jan 12, 2023 01:39 PM
MoparDude
Jul 18, 2021 01:12 AM
Oxidizer2k
Dec 24, 2020 12:35 AM
