Key won't lock or unlock drivers door
Old Dec 22, 2013 | 05:40 PM
TreVoRTasmin's Avatar
Default Key won't lock or unlock drivers door
Went to NYC this weekend and gave the valet key to the hotel only to have them come and say they couldn't lock the door. Seems none of my keys will lock or unlock the door but will open all the windows. Key fobs work just fine. Any ideas what the issue might be?
Keys work the trunk and glove box just fine.
Old Dec 24, 2013 | 12:31 PM
Anyone?
If not has anyone taken it apart? I'm assuming it is all mechanical not electronic but before I open it hope hoping for some input.
Old Dec 24, 2013 | 01:34 PM
jimlombardi's Avatar
Look at post #14 in the following thread on driver door lock R&I:
https://www.jaguarforums.com/forum/x...h-cable-84285/
Also
https://www.jaguarforums.com/forum/x...-issue-106708/
and this DIY forum thread - posts #1, 6, 8 and 11:
https://www.jaguarforums.com/forum/x...ics-faq-67357/
Jim Lombardi
Old Dec 26, 2013 | 04:16 PM
Thanks Jim, I did see those prior to posting and none of them seem to fit my bill. Key fob works just fine door locks and unlock just fine inside as well. Key goes in and turns without a problem but doesn't unlock or lock it. I'm just kind of wondering what I might need before I take it apart. That way I can buy some used parts.
Old Dec 26, 2013 | 08:33 PM
motorcarman's Avatar
The link rod is missing or disconnected from the lock cylinder in the handle.
bob gauff
Old Dec 27, 2013 | 01:32 AM
I researched the door lock link rod that is attached to the barrel cylinder lock.
The door lock link rod consists of 2 parts - link rod (part number GNA1111AB) and linkage clip (part number GNA1122AA)
Here is weblink to a JPEG that shows the R&R steps related to the door lock link rod, also has a photo of these 2 parts assembled on the door latch from Ebay listing -look at step 10 (click on image when webpage to get a larger view on images):
https://www.dropbox.com/s/nx2598af86...ock%20info.jpg
Jim Lombardi
Old Dec 28, 2013 | 06:09 PM
Thanks Jim, I owe you a beer token! Now I just need to wait for a warm day to take it apart as next week looks a little bitter.
Wish I could get JTIS to download into my windows 8 and work.
Old Dec 28, 2013 | 06:36 PM
Lear45's Avatar
My guess is the linkage clip. The one in the trunk in plastic and they eventually break.
I am guessing the door is about the same. Fix it sooner rather than later. If the car
battery is dead, your FOB won't work.
Old Dec 28, 2013 | 10:11 PM
Here is another forum thread with more instructions & illustrations on the front door handle/lock r&r info (see post# 5 in that thread):
https://www.jaguarforums.com/forum/x...y-ideas-50196/
the called out Front Door Trim Panel Finish Panel 76.47.11
you can skip - step 2. Remove veneer panel from casing
I recall that we did not have to remove the veneer panel the last time we removed the door panel (also known as the door card in TV series - Wheeler Dealers).
Jim Lombardi
99xk8guy
Sep 29, 2025 10:51 PM
Wolfy
May 28, 2024 08:06 AM
D.K
Dec 10, 2023 02:05 AM
XJsc-guy
Nov 23, 2015 01:56 PM
tberg
Sep 7, 2015 07:32 AM
