looking for steering u joint coupler,urgent
Old Oct 18, 2014 | 01:51 PM
vincent661983's Avatar
Default looking for steering u joint coupler,urgent
I need a steering coupler/u joint between the steering rack and column.
I totally lost the steering because the teeth/thread on the coupler is not biting anymore
sorry my car is 2000 XJR
Old Oct 18, 2014 | 05:27 PM
jimlombardi's Avatar
Here is parts diagram of the lower part of the steering column :
1 + Steering column
+ lower
+ LHD
+ To VIN (F20644) HNC9501BC
+ From VIN (F20645) To VIN (F22200) MNE9501AB
+ From VIN (F22201) To VIN (F44409) MNE9501AC
+ From VIN (F44410) MNE9501AD
Here is a used one for sale on Ebay for $22.74 free shipping from Georgia:
Jaguar XJ8 98 99 Lower Steering Column Rag Joint Knuckle 14696 | eBay
and another for about $35 with shipping:
1998 2003 Jaguar XJ8 Lower Steering Column Joint Knuckle Part | eBay
Gaudin Jaguar website shows the part number now superceded - its part now is MNE9501AD and their discounted price is $468.98 plus shipping ---- They also show this other parts diagram:
[ 2 ] STEERING COLUMN / STEERING COLUMN / STEERING COLUMN / LOWER SHAFT
Part Number: MNE9501AD
lower shaft XJ, XK; Sedan XJ, XK SERIES
Parts And Prices Are For Estimating Purposes Only. MSRP Core ? Online Price
$577.20 $0.00 $468.98
[ 11 ] STEERING COLUMN / STEERING COLUMN / STEERING COLUMN / COUPLING
Part Number: C2P4612
coupling XJ, XK; Party Of Lower Shaft XJ, XK SERIES
$71.59 $0.00 $62.64
Note item 11 looks interesting - maybe its the replacement part you need????
I also did a web search using the C2P4612 and found the following diagram on Parts.com website:
Item #6 is part#C2P4612 --- COUPLING- Steering Column - LOWER JOINT
Online Price: $60.13 C2P4612
Jim Lombardi
Attached Thumbnails looking for steering u joint coupler,urgent-sh6385.jpg   looking for steering u joint coupler,urgent-f300116.gif   looking for steering u joint coupler,urgent-f302060.gif
Old Oct 18, 2014 | 08:05 PM
This is what i need,Jim
Old Oct 18, 2014 | 10:34 PM
Here is a better photos of the lower steering column - Ebay listing $50 shipped-
1998 2003 Jaguar XJ8 Steering Wheel Column Joint MNE9501AC | eBay
Jim Lombardi
Attached Thumbnails looking for steering u joint coupler,urgent-2000-xj-lower-steering-columnebay1.jpg   looking for steering u joint coupler,urgent-2000-xj-lower-steering-columnebay2.jpg   looking for steering u joint coupler,urgent-2000-xj-lower-steering-columnebay3.jpg
Old Oct 18, 2014 | 10:43 PM
Sorry,jim. In fact i also brough this but its not right. I think i need item 6
Old Oct 18, 2014 | 11:06 PM
Maybe this one on Jaguar Parts International website - item 3 (U joint coupling) on diagram:
https://jaguarpartsinternational.com...agramCallOut=3
Jim Lombardi
Attached Thumbnails looking for steering u joint coupler,urgent-2000-xj-lower-steering-column-u-joint-couplingebay3.jpg
Old Oct 19, 2014 | 10:52 AM
Jim,mine is MY2000,a x308 as you know but your resource is for 2009?
This is the last u joint between the rack and steering column shaft
Old Oct 19, 2014 | 11:34 AM
I noticed that but it has the same part number as (in post#2) Item #6 is part#C2P4612 - and item# 11 STEERING COLUMN / STEERING COLUMN / STEERING COLUMN / COUPLING.
Jim Lombardi
Old Oct 19, 2014 | 03:11 PM
So it's the same part for x308?Jim.
I need to order it ASAP
Old Oct 20, 2014 | 01:49 PM
Jim, I just went to the Jaguar dealership in Manhattan to order that coupler, like what you found, only for later X350 has this coupler sold alone
I hope (crossing finger) it fit my X308 as they visually look identical but in jaguar's term. it is not always the case.
side story. the dealer is under new ownership. very bad management , one person does not know another person does there at all and pointing me all around thou the part guy is cool.
Old Oct 25, 2014 | 01:27 PM
Bad news, the coupler i got from the dealer wont fit
Back to zero and now i am so desperated
Old Oct 25, 2014 | 04:56 PM
Sorry it does not fit.
Look at this ebay listing:
1998 2003 XJR Steering Wheel Column Lower Connector Yoke Shaft | eBay
Jim Lombardi
Old Oct 26, 2014 | 03:59 PM
XKRacer's Avatar
Not sure it helps but the part you are after looks identicle to what they use on XKs, its the UJ that actually joins onto the rack?
Old Oct 26, 2014 | 10:00 PM
andyrewj's Avatar
This is the part I have. Mine is from a 1999 XJR. Looks like the 2000 is different.
Old Oct 27, 2014 | 10:06 AM
I just found another coupler from ebay and the donor car is from the exact MY2000, I hope the nightmare is over
it is fxxking stupid that Jaguar does not sell the coupler alone for our X308 for force people to purchase entire column shaft for a lot of money.
as my fellow members owning the same car, I think my frustration is realistic.
people here saying X308 is a relative a reliable built car, I respect their opinion based on their own experience. but 100% definitely not my case.
everything should break down over the years, happened. for those should not happen, they all are broken down.
I can not think of one part of the car that I did not need to fix
Old Oct 27, 2014 | 02:40 PM
The follwing TSB (Jaguar Service - Technical Bulletin) shows the lower steering Column and its install instructions.
TSB 211-06 Steering Rack Knocking Or Rattling - Revised Lower Steering Column/Rack Return Line – Repair Procedure PDF file:
https://www.dropbox.com/s/njtwx7lm09...tling.pdf?dl=0
Jim Lombardi
TreVoRTasmin
Feb 23, 2021 03:13 PM
xjrjag
Oct 12, 2015 03:16 PM
Delta66
Oct 4, 2015 05:40 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
