loud clunk when braking
Old Sep 22, 2013 | 07:19 AM
DJ-Roy's Avatar
Default loud clunk when braking
Just got the car back ,they fitted another diff.
It hopefully has nothing to do with that last repair but..after getting it back
When i pump the brake pedal when coming to a stop ,
The car clucks and jumps up and down ,it sounds and feels like the brake calipers are
loose ...but of course they not..
Could it be the subframe mountings ,? this really scares me ,any ideas
Where to look first,?
Another problem ,i also have a ABS Trac /Stab light
When i drive the car and it goes in second gear the light goes out....{i will
Have it checked for codes} ,hopefully thats only a ABS sensor lead ...
Old Sep 22, 2013 | 08:51 AM
sparkenzap's Avatar
How do know the calipers aren't loose. I had one of mine come loose a few hundred miles after I purchased the car...
Old Sep 22, 2013 | 09:50 AM
princemarko's Avatar
Open the hood.... drive 5-10mph and hit the brakes... if you see the engine shift up, its the subframe mounts
Old Sep 22, 2013 | 11:09 AM
Jhartz's Avatar
Go with the obvious: if they replaced the diff, everything along the drive train and axle was removed: something was not bolted up correctly. Get it on a lift. Calipers, first, driveshaft universal rubber connectors worn or badly placed, some bolt left off or night torqued.
Old Sep 22, 2013 | 11:35 AM
Sean B's Avatar
or engine mounts, with one foot on the brake, rev the engine lightly see if there's abnormal movement from the engine.
I'd be suspicious of the recent work too, if the above checks don't reveal anything, it's got to go back to the shop you had the diff change work done, and show them.
Did you get the shock bushes done too?
Old Sep 22, 2013 | 03:38 PM
DJ-Roy's Avatar
Thanks you very much for the input everyone!
@Sean ,I ordered the rear lower shock bushings ,
The engine mounts and rear trans mount are new ,
Hoped that would solve the problem but it is still there .
I already went back to that garage that placed the diff ,,
They found a front Cats Shock with movement on the Shock Shaft ....replaced that shock and bush so thats tight ,
But still the heavy shuddering and bounce under pumping repeated application of the brakes.
@Jhartz
I also thought they made a mistake with the rear diff swap ,
But the knock really seems to be coming from the front ,even though its sometimes difficult the locate a problem on these cars ...if the front subframe bushings are ok then the rear is the next to look at...
Just found that it dont knocks and bounces , when i repeatedly apply the Brake pedal .. .......when i drive backwards.
Old Sep 23, 2013 | 05:54 AM
Sean B's Avatar
front subframe Vee mounts are sounding more likely at this point
Old Sep 23, 2013 | 07:37 AM
Leave the hood up... drive FORWARDs 5-10mph and hit the brakes hard... look at the engine...it if shifts up, its certainly your Vee mounts
Old Oct 14, 2016 | 01:32 AM
Satakewawa's Avatar
Curious, what was the problem?
mbergen
Oct 23, 2019 10:26 PM
Razor
Aug 28, 2019 08:34 PM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
philwarner
Sep 16, 2015 10:40 PM
Johnken
Sep 15, 2015 05:46 PM
