Lug Nuts for 2003 Jaguar XJR
Old May 1, 2014 | 12:19 AM
zubizar's Avatar
Default Lug Nuts for 2003 Jaguar XJR
I have spent hours reading threads on lug nuts and am more confused than ever. Would someone please tell me which aftermarket lug nuts are available for a 2003 Jaguar XJR? Please provide manufacturer, part numbers, links, HELP. Going on long trip and need to replace lug nuts that are missing washers and otherwise look crappy. Thanks from a confused newbie.
Old May 1, 2014 | 09:37 AM
Cabezagrande's Avatar
It's a 1/2-20 thread, but is a shank style nut, so your typical tapered acorn nut does not work. You pretty much have to get them from a Jaguar parts supplier. The best price I've found is at Welsh Enterprises.
Welsh Enterprises - New Jaguar Parts, Used Jaguar Parts and Accessories - XK120 - XK140 - XK150 - E-Type - MK - XJ6 - XJ8 - XJ - XK8 - XK - XJS - S-Type - X-Type - XF
The only place I've ever found them locally was at the Jag dealership, and they were a small fortune each.
You might try these McGard parts. Not entirely sure they'll work though, I have not tried them.
Chrome Regular .746" Shank Style Lug Nut Set (1/2"-20 Thread Size) - Set of 4 Lug Nuts and 4 Washers
Old May 1, 2014 | 04:30 PM
vincent661983's Avatar
1/2-20 is for sure, took a a great deal of research and learning about nut dimensions from thread size, length depth during my wheel conversion with different bolt pattern
Old May 1, 2014 | 05:04 PM
jimlombardi's Avatar
zubizar
Member EyeDoc thread about lug nuts he purchase on Ebay for his 1998 XJR "they fit perfectly":
Here is the link to that thread:
https://www.jaguarforums.com/forum/x...it-x308-81007/
They are still being sold on Ebay - 20 Lugs Chrome Lug Nuts 1/2" Mag Shank Style 13/16" Head .72" Shank - condition new (buy it now price $23.25):
20 Lugs Chrome Lug Nuts 1 2" Mag Shank Style 13 16" Head 72" Shank | eBay
Jim Lombardi
Old May 1, 2014 | 07:41 PM
zubizar's Avatar
Default Eyedoc Says they Rusted
Quote from Eyedoc:
"They will fit 98-03 (XJR). I ran mine through one winter.
They are rusting out already. I wouldn't buy them again."
These are a no go for me. Thanks for sharing info.
Old May 1, 2014 | 09:45 PM
Info on wheel nuts from Jagbits:
CCC7028- Jaguar 1980-1997 XJ6, 1997-2006 XK8, 1998-2003 XJ8, XJR AND XJS WITH LATTICE WHEEL
Jagbits sells it for $12.99 each
Welsh Enterprises sells the Jaguar wheel nuts (part# CCC7028) for $8.95 each.
Welsh Enterprises, Inc - Jaguar Jaguar Wheels Parts - Lugnut - Short - XJ6 XJS XJ8 XK8
Jim Lombardi
Old May 2, 2014 | 06:56 AM
zubizar
Look at member burmaz posting in the Would these lug nuts fit (post #5):
His quote "These are the exact lug nuts I bought. They fit the asteriods perfectly."
He had a weblink to this ebay listing (that is now closed) Ebayer was dpaccessories
Chrome Factory/OEM Toyota/Lexus/Scion Style Wheel/Lug Nuts, 1/2-20, Set of 20
But I did find the same ebay listing by dpaccessories currently offered ($23.35 price):
Chrome Factory OEM Toyota Lexus Style Wheel Lug Nuts Mag Seat Qty 20` | eBay
Ebay reviews on seller are mixed (some good and some not so good).
You should contact member burmaz about the lug nuts he purchased from them in Sept 2012.
Jim Lombardi
Old May 6, 2014 | 05:50 PM
zubizar's Avatar
Smile Thank You
Thank you CabezaGrande (Big Head) and JimLombardi. I went with Welsh Enterprises for $8.95 per lug nut. Original OEM. I guess you can't go wrong at this price point for a factory part. You guys saved me a lot of money. Cheers.
Old May 6, 2014 | 10:21 PM
avt007's Avatar
As always, you have to be careful with a 2003 XJ-anything, as in some markets it's an X308, and some it's an X350.
So know which you own ,and know which the vendor thinks an '03 is.
Old May 6, 2014 | 11:32 PM
grandell's Avatar
It's always good when buying parts to quote the model number (X300/X308/X350), rather than just the year. And of course, if you can, the actual part number.
Avoids confusion about cars at the start and end of model runs
neruda
Sep 3, 2015 07:45 PM
big d
Sep 3, 2015 07:37 PM
dpappyp
Aug 27, 2015 06:31 AM
Zues
Aug 27, 2015 12:02 AM
Terrance Williams
Aug 26, 2015 11:50 AM
