Need Help Replacing Thermostat Please
Old Dec 20, 2014 | 09:08 PM
johnnyjag89's Avatar
Default Need Help Replacing Thermostat Please
how do I replace a thermostat in 1999 xj8 ?is there a video
Old Dec 20, 2014 | 09:33 PM
I've moved your post from the General Tech section to the XJ (X308) section where it will get greater visibility and members/techs familiar with this model can best assist
regards,
Steve
Old Dec 24, 2014 | 01:05 AM
jimlombardi's Avatar
I put the following information together -
Radiator Drain plug location
Engine Trim Covers
Replacing the Thermostat
Jim Lombardi
Old Dec 24, 2014 | 07:02 AM
JimmyL's Avatar
I like the rubber seals much better than gaskets. It's the same with the valve covers and the water pump. You just smear some a little Vaseline on them and tighten just enough to squish the seal. 8 Nm equal 5.9 pound feet of torque - not much.
Old Dec 24, 2014 | 08:14 AM
RJ237's Avatar
You might want to consider changing the thermostat tower to the aluminum type available from many sources like Welsh Enterprises. This is because the plastic part becomes brittle with age and is liable to crack when you change the thermostat.
Old Dec 24, 2014 | 08:53 AM
forum member xjay8 uses a 2 way suction pump to remove enough coolant to do repairs:
The only Hand suction pump that I could find is on the Harbor Freight website
Looks like you have a local Harbor Freight store (1460 South Broadway, Santa Maria, CA 93454 (805) 922-4337)
Jim Lombardi
Old May 6, 2015 | 11:10 PM
EscapedApe's Avatar
Hi Jim,
Are these instructions similar for the XJR Supercharged (2001)?
Old May 7, 2015 | 06:19 AM
RJ237's Avatar
Originally Posted by EscapedApe
Hi Jim,
The XJR thermostat is not in a tower, it's in the crossover pipe where the left hose connects. Oter than that, the procedure is much the same.
Old May 7, 2015 | 09:00 AM
EscapedApe
Here are the JTIS info on replacing the thermostat for your XJR:
Jim Lombardi
Old May 7, 2015 | 04:15 PM
EscapedApe's Avatar
Thanks Jim for the diagram - looks like it's going to be easier than the non-supercharged versions
Old May 8, 2015 | 07:01 PM
margate69's Avatar
Actually both models are really simple, 3 bolts on each. The problem with the normally aspirated car is the plastic housing. Your car doesn't have that problem to deal with, so you're lucky.
But with either model, I don't even take the radiator hose off. I just remove the bolts, pop the t-stat out, put in a new one, bolt it back up. Good to go.
Forcedair1
Sep 8, 2025 01:57 PM
Doug
Feb 27, 2019 01:31 AM
KarimPA
Sep 12, 2015 08:15 AM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
