No beeps when using remote fob
Old May 17, 2020 | 12:28 AM
3timejag's Avatar
Default No beeps when using remote fob
Anybody have an idea why I am not getting those classic “beeps” when I lock and unlock my 1998 XJ8 remotely? Everything is working fine, except for that.
many thanks in advance!
Old May 17, 2020 | 08:13 AM
motorcarman's Avatar
The 'sounder' is just in front of the ABS actuator/module (behind the left headlamp assy).
You might check it for bad connection or a 'failed-unit'?
Old May 17, 2020 | 08:43 AM
3timejag's Avatar
Excellent! I had no idea where to even look or how to approach this. Many, many thanks!
Old May 17, 2020 | 11:28 AM
3timejag's Avatar
Okay, I’ve been looking for a half hour and I can’t find it! I’ve been “beeping” with my other XJ8 trying to locate it, and no matter where I stand, it sounds like it’s coming from in front center of the radiator. Any way to CONVENIENTLY send a pic of this “module” or small speaker, whatever it is?
Old May 17, 2020 | 11:36 AM
I am pretty sure that the 1998 is in a different location from the 2003.
bob
Old May 17, 2020 | 11:50 AM
3timejag's Avatar
Well that would make sense then...okay, can you describe what it looks like? I don’t see anything resembling a speaker or a horn, anything may help. Thank you motorman!
Old May 17, 2020 | 11:51 AM
The 1998 'parts car' I have is different from my 1999, 2000 and 2001 sedans.
The 1998 is where I stated but the others have it under the 'frame' structure under the left headlamp area.
Old May 17, 2020 | 11:52 AM
3timejag's Avatar
Is this it?
Old May 17, 2020 | 11:53 AM
3timejag's Avatar
I didn’t see this before I posted the picture of the alarm siren. Was thinking they were one in the the same . Thank you so much!!
Old May 17, 2020 | 12:03 PM
3timejag's Avatar
Mine is completely missing, nothing in that space! Okay, at least I know what to look for...unless you are selling parts off of your ‘98?
Old May 17, 2020 | 12:26 PM
I would look in the place where the 2003 sedan has it before you determine that the 1998 is missing. Might be some sort of VIN change and the location is different?
Old May 17, 2020 | 12:28 PM
3timejag's Avatar
Well, it is a Vanden Plas, so maybe it is different. I found one on eBay though.
Old May 17, 2020 | 12:34 PM
3timejag's Avatar
Okay! Just got under the car and found it, disconnected! I reconnected it and it’s now working...thank you my friend, you made my day!
acetrebo
Aug 6, 2020 11:31 AM
MyLuxury2017
Feb 20, 2018 01:04 PM
maringa
Nov 17, 2015 02:24 AM
John S
May 14, 2015 07:03 PM
YoungRobertL
Feb 12, 2012 10:46 PM
