OBD port issue
Old Jul 3, 2024 | 01:24 PM
vincent661983's Avatar
Default OBD port issue
Hi to all
I am having a strange problem with the OBD portion connection. my mechanic was able to connect it with his scanner but when trying to do the NY state inspection. His computer would not reading my car. ( he was able to do the state inspection for the other cars thou)
Old Jul 4, 2024 | 08:59 AM
David N. Warner's Avatar
I am having a strange problem with the OBD portion connection. my mechanic was able to connect it with his scanner but when trying to do the NY state inspection. His computer would not reading my car. ( he was able to do the state inspection for the other cars thou)[/QUOTE]
I have had my OBD scanner claim is was not connecting at times on my cars. Not sure what the problem is but generally disconnecting and reconnecting would make it work again. Perhaps try a different test station? BTW; do you have an OBD reader? Does it connect and if so, do you have any current OBD problem codes being reported?
Old Jul 4, 2024 | 02:36 PM
Jhartz's Avatar
. . . said another way: get a mirror and look at the pins in the OBD connection, if any are bent, you (or the inspector) will not be able to connect.
Old Jul 4, 2024 | 04:47 PM
Hi, i have stated obd port connects to the scanner without problem but when connects to the inspection computer..it can not read my car.
Old Jul 4, 2024 | 09:44 PM
RandyS's Avatar
Ha... and you would think they would have enough experience to figure
out the issue.
Old Jul 4, 2024 | 10:43 PM
Don B's Avatar
I have a very high-end Autel MaxiSys Elite scan tool that does not like to communicate with our 2003 XJ8, so instead I use my Launch Creader VIII, which may be 10 years old. I suspect there is a problem in the software in the Autel that causes it to not recognize the X308. Ask your mechanic if he has an older scan tool he can try on your car.
Cheers,
Don
Old Jul 5, 2024 | 12:35 PM
Jhartz's Avatar
Again, does your OBD scanner connect and read NOW? If so, the issue is at the inspector. Take the car back, connect your scanner and show him the P1111.
Maybe he has an older scanner.
Recognizing it is New York! What's happening to my Yankees?
Old Jul 5, 2024 | 12:51 PM
hispeed42's Avatar
I have an Autel MX808 MaxiCheck and haven't had any problems connecting. Do you subscribe to the updates?
Old Jul 5, 2024 | 03:31 PM
JagV8's Avatar
I think I would not show a P1111 - it's Jaguar-specific and anyway a pending code so doesn't count for smog.
His OBD tool should use the proper OBD stuff e.g. to read OBD monitor status as well as DTCs.
Old Jul 5, 2024 | 03:59 PM
RandyS's Avatar
Nahhhh...just show the inspector that your OBD port is working and the
problem is with his connection,,,not your OBD port.
Old Jul 5, 2024 | 07:39 PM
Don B's Avatar
Yes, I re-subscribe the MaxiSys Elite about every 2 or 3 years when they have a 50% off sale, and about the same for my four or five other lesser Autel tools (MaxiCheck, etc.) During the 12-month periods when the tools have active subscriptions, I install all the relevant updates that are offered for vehicles I work on.
Old Jul 6, 2024 | 05:11 PM
hispeed42's Avatar
With that unit it and price for updates, I'm surprised that it won't hook up. I'm not running a shop, so the MaxiCheck is perfect for my needs and I occasionally have neighbors with a CEL that drop by, so I keep it updated. I'll have to start looking for those subscription sales.
Old Jul 6, 2024 | 09:34 PM
Don B's Avatar
If you registered your Autel, they should send you emails when they are having discounted sales on the subscriptions.
Old Jul 8, 2024 | 02:59 PM
hispeed42's Avatar
I did, and they do. But, those emails go to the "Promotions" box in gmail, and I usually only go there to clean it out. I'll have to fix that so the emails show up in the inbox.
WCats
Jan 24, 2022 02:37 PM
Traindriver69
Apr 8, 2021 04:44 AM
JustNiz
Apr 16, 2017 11:41 AM
