OBDII Not working cont'
Old Sep 3, 2015 | 10:43 AM
Bcrary3's Avatar
Default OBDII Not working cont'
So, my OBDII connector still isn't working even with a known compatible scanner...
Some suggestions so far are to check for bent pins (done, and clear)
Disconnect the ECU, trans ECU, and any other suspect plugs.... I am not sure of the location of these items.
Another things I am thinking, would it be possible to use an ECU out of a 2000 XJ8 on a 2000 VDP?
Could the ECU be the issue of why I cannot pull the codes?
Old Sep 3, 2015 | 10:51 AM
WhiteXKR's Avatar
Check fuse number 4 of the left (US driver's side) rear seat floor fusebox and fuse number 10 on the right (US passenger side) rear seat floor fusebox.
Old Sep 3, 2015 | 11:03 AM
Bcrary3's Avatar
I will give that a try when I get home this evening.
Old Feb 16, 2017 | 08:17 AM
keplaa's Avatar
Lightbulb
Are you certain that your scanner is working correctly ? Is it managing to communicate properly and get codes from another vehicle ?
When you connect the scanner to the OBD-II port and then switch the ignition on, does your scanner start making attempts to communicate with the vehicle's ECU and then report some kind of error with the comms ?
Do you, or a friend, have access to another ODB-II scanner that you can try on your car to see if it does anything ?
Do, also, check over the fuses supplying the ECU, the wiring and the plugs going into it. Also the points nearby where the wiring harness connects to the frame of the car. Slight voltage drops, due to dirty, loose or corroded connections at any of those points can play absolute havoc with the operation of the ECU ! I've been there - more than once.
It is possible for an ECU to fail, but bad connections or a bad scanner are more likely - so verify these first. Does the car's engine start and run. If so, then the ECU is providing at least some functionality and may well be attempting to communicate with your scanner, albeit not perfectly.
Good luck - let us know how this goes won't you ?
Old Oct 30, 2018 | 01:27 PM
annamiata's Avatar
I also bought Icarsoft 930 new on Ebay couple years ago to diagnose airbag warning and suspension warning. It will read codes for suspension, air bag, abs, climate , transmission etc. However, I do get "Communication Failure with ECU" for engine code when attempt to read P engine codes. I did not realized this till a year later after purchase. I updated firmware from Icarsoft but it did not help. As such, I do use a second OBII reader for the standard P code.
Icarsoft I930 also works on my 1997 XJ6 and 2003 S-type
I would buy it again even it does not read ECU for P codes since it scanned for all others Jaguar's special codes.
Old Oct 30, 2018 | 01:41 PM
JagV8's Avatar
Did you update its software?
Old Oct 30, 2018 | 08:24 PM
astark's Avatar
I have the icarsoft i930 and it reads all codes on my 1999 XJ8 without any problem for whatever that's worth, don't know why yours does not when it should.
Old Mar 27, 2021 | 04:27 AM
gerardbooth's Avatar
Story to resuscitate an ancient thread, but did anyone ever get hold or share the dimensions of that home made tie bar for the sway bar to mount to...
Old Mar 30, 2021 | 07:50 PM
rocklandjag's Avatar
Ancient thread? No way - still works like new!
Unfortunately I don't have the dimensions any more but I can measure it next time I am under the car.
Old Mar 31, 2021 | 01:17 PM
jeff xj8's Avatar
Yeah, what WhiteXKR said worked for me.
I had no power at OBD port. (Locksmith could not program key he had just made for me)
I located and changed that fuse and it solved my problem.
jeffxj8
Old Apr 23, 2021 | 02:20 PM
Jesse Korrell's Avatar
Default Where is this fuse located?
jeffxj8
Where are these fuses located?
Old Apr 27, 2021 | 01:25 PM
jeff xj8's Avatar
right hand rear fuse box below rear passenger seat. behind heel kick panel. fuse 10. worked for me
Old Aug 4, 2021 | 06:41 AM
Koley's Avatar
I have this problem and ive checked all fuses. The scanner works on my x300 but not on the xjr. I even scanned it at a mechanic and they did not either get any contact. But they managed to see the rpm when the car was on.
Old Sep 10, 2021 | 09:25 AM
Justin's Jag 1994 XJS's Avatar
Hi All,
I have a 1994 XJS and the transmission is currently in fail-safe mode (I recently had the alternator replaced). I brought the car to a transmission specialist however they cannot read the codes on the 1994 model. I was told this was before the universal OBD that became available on the 1995 models. I was also told that there were two transmissions used in the 1994 model, the US model and the Asian model. I have the Asian model.
Does anyone know how I can read the computer codes on my 1994 XJS so that the transmission can be properly diagnosed?
Thanks!
Old Sep 11, 2021 | 04:30 PM
JagV8's Avatar
Looks like you're in the wrong forum
Old Sep 11, 2021 | 04:32 PM
I'm new to this , so I'm open to suggestions. Thanks
Old Sep 12, 2021 | 05:41 AM
JagV8's Avatar
I suspect you should be in one of the places under https://www.jaguarforums.com/forum/j...s-classics-78/
Eskr
Apr 23, 2017 02:30 AM
Jhitchin1
Feb 16, 2017 09:35 AM
Madbrad
Jul 22, 2015 07:49 PM
Ettengerg
Jun 15, 2015 03:44 PM
rweber
Nov 18, 2010 10:48 AM
