Oil leaking from 2 engine sensor sockets? What are they?
Old Jan 25, 2015 | 10:31 AM
vdpnyc's Avatar
Question Oil leaking from 2 engine sensor sockets? What are they?
What are these electrical sensors on each side of the front-segment of the engine block? Should I be concerned about slight oil leaking out from each of them?
Drivers-side
passenger-side
Old Jan 25, 2015 | 10:35 AM
test point's Avatar
Not exactly on the engine block but the valve covers. Those are the variable valve timing (VVT) solenoids and a simple 'O' ring replacement will solve the problem.
Not a critical issue, only messy. Wipe it off and spray the remaining with some brake cleaner and it will be good for a few months.
Old Jan 25, 2015 | 10:50 AM
vdpnyc's Avatar
Thank you
If I do nothing about it until the summertime (besides occasionally topping of the oil), will anything bad happen?
I've got some mission-critical 1,500-mile drives to do and am afraid to mess with a working engine prior...
Old Jan 25, 2015 | 11:15 AM
test point's Avatar
Just get messier.
Old Jan 25, 2015 | 11:16 AM
retromotors's Avatar
Originally Posted by vdpnyc
......If I do nothing about it until the summertime (besides occasionally topping of the oil), will anything bad happen?....
Nah .... you're good to go.
As test point said, it's just a minor cosmetic issue.
Happy motoring!
Old Oct 3, 2016 | 12:34 AM
vdpnyc's Avatar
Any idea what o-ring size to use?
(and yes, it's taken me 21-months to get around to fixing this, lol)
Old Oct 3, 2016 | 07:29 AM
BobRoy's Avatar
They are specific for Jaguar. The part # is
AJ82856. I recently saw them at AutohausAZ for about $5ea. Go to the dealer and they are proably $40ea.
Old Oct 3, 2016 | 05:23 PM
vdpnyc's Avatar
Thx - FYI rock auto is slightly cheaper than autohaus after accounting for s/h.
Old Oct 5, 2016 | 09:41 AM
vdpnyc's Avatar
Trivial question, but to remove the sensors to access/change the o-ring, do they unscrew with regular full threads like a spark plug, do I do a partial turn (like 90 degrees) on them then pull out or something else?
Old Oct 5, 2016 | 09:53 AM
WhiteXKR's Avatar
You DO NOT remove the sensors (actually solenoids) to change the seals. Just unplug the solenoids, and pry the lip of the seals straight up with a small screwdriver, working your way around a little at a time. Be sure to clean the dirt off of the solenoids before refitting the new seals.
Old Oct 5, 2016 | 10:21 AM
vdpnyc's Avatar
Glad I asked, lol - so is that the seal ring visible in the photo?
Old Oct 22, 2016 | 07:09 PM
vdpnyc's Avatar
After 22-months of procrastination, I just swapped both rings and cleaned the oil off the engine in a total of 7-minutes, lol. Very easy job.
FYI, to anyone needing to mess with the solenoids, there is a tiny tab at the top of the electrical connector just over where the wires attach to it, depress that and the plug removes easily.
Old Dec 17, 2016 | 08:16 PM
Bcschro's Avatar
can anyone tell me where I can get the plastic wire connector. mine is broken and hoping I don't have to replace the whole wire harness for one little plastic connector
BrentGardner
29
Dec 16, 2024 12:13 AM
Torrid
Feb 15, 2020 08:03 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
peterg19
Aug 28, 2015 08:42 AM
dpappyp
Aug 27, 2015 06:31 AM
