P0456, 2002 Sport
Old Mar 5, 2018 | 11:12 PM
Z07Brandon's Avatar
Default P0456, 2002 Sport
Hey guys. Got the p0456 code yesterday. Car is running fine, despite the code. Should I replace the gas cap?
Old Mar 6, 2018 | 01:35 AM
JagV8's Avatar
If it's the cause, yes.
It's not quite running fine, BTW.
Old Mar 6, 2018 | 07:45 AM
Z07Brandon's Avatar
What do I to do to diagnose it? I believe a smoke test won't reveal any leaks since it's, "very small", or am I wrong? AFR's are pretty much, or at 14.7 most of the time, btw. But obviously don't want to have the light on.
Old Mar 6, 2018 | 01:17 PM
JagV8's Avatar
Check each of the causes it can be - yes one is unsealed gas cap. You could start with that and see if it fixes it. The workshop manual usually lists all the possible causes.
Old Mar 6, 2018 | 04:02 PM
Z07Brandon's Avatar
Thanks. I Really gotta get one world those manuals!
Old Mar 6, 2018 | 04:17 PM
RJ237's Avatar
https://www.jaguarforums.com/forum/x...archive-66011/
Old Mar 12, 2018 | 10:04 AM
Z07Brandon's Avatar
I saw when I searched the code. Good read and thanks! Leaving work Friday, the check engine light was not lit anymore. Never replaced anything. Yes, the light still works. I guess don't worry about it until the light shows back up?
Old Mar 12, 2018 | 11:20 AM
RJ237's Avatar
If you don't have a code stored, there is nothing to fix.
Old Mar 12, 2018 | 06:43 PM
JagV8's Avatar
Well.... yes - so long as it's not stuck trying to set OBD monitors (it can then be unable to flag codes).
Old Mar 25, 2018 | 12:19 AM
Z07Brandon's Avatar
Does anyone know where I can get the CCV pipe?
nixx
85
Mar 21, 2017 07:15 AM
J.Bo
Jun 6, 2012 12:13 AM
H20boy
Nov 6, 2011 06:16 AM
targa81
Sep 17, 2011 07:45 AM
HUMMERSA
Jun 6, 2009 01:00 PM
