Quick Head Bolt Question
Old Jan 21, 2014 | 03:26 PM
BW_Hunter's Avatar
Default Quick Head Bolt Question
Hi Folks,
I'm getting ready to reassemble the engine and, obviously, need to replace the head bolts. I understood that the Land Rover bolts are cheaper and looked into them. I found part number 4677857G for all 4.2, 4.4 and 5.0 Jaguar engines. At $35.xx for a set of 10 for 1 head I was pretty pleased. Now for the question: The illustration shows these bolts to be allen head instead of the hex heads that came out of my engine. Is this what I should expect and is there any concern switching to allen head over hex?
If that isn't the right part number, I'd sure appreciate a little guidance into the right one.
Thanks for any help....
Old Jan 21, 2014 | 07:13 PM
sparkenzap's Avatar
Mine were torx head as I recall. T65??? And no, the Torx are probably easier to work with!
Old Jan 22, 2014 | 05:30 AM
Sean B's Avatar
Order one to check length, I didn't know they fit 5L too - the Torx head was an upgrade by JLR because the originals round off too easy. They will do the job perfectly if the same length, your original might be ever so slightly longer due to necking on torque down.
Old Jan 22, 2014 | 06:30 AM
BW_Hunter's Avatar
That's a good point about the slight stretch....
The bolts are listed as M10 x 175mm TTY which al sounds right. I'll buy 'em and compare.
Take care,
Old Jan 26, 2014 | 07:54 AM
dc4prez's Avatar
m10 x 175mm is the correct length
Victor reinz and elring also make bolt sets for around US$150.00 for the 20 plus 4 bolts
victor reinz part number is GS33527
Old Jan 26, 2014 | 09:07 AM
motorcarman's Avatar
Jaguar did issue a TSB and Mandatory Special Tool 303-1077 RIBE bit for the cam sprockets.
There is a difference between RIBE and TORX. They are both 6 point but the similarity ends there.
I don't know if the head bolts are RIBE or TORX but Jaguar has issued this tool.
BMW uses TORX on some heads.
VW/Audi uses RIBE on some heads.
Just thought I would mention this and see if anyone knows what Jag is using.
bob gauff
Old Jan 26, 2014 | 09:11 AM
test point's Avatar
Check RockAuto for the bolts for a Lincoln LS 2002, FEL-PRO Part # ES72262. For one head, $31.79.
Old Jan 26, 2014 | 09:35 AM
I have used the FELPRO bolts. They work fine (I keep them in stock).
bob gauff
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
al_roethlisberger
Sep 11, 2015 10:04 PM
Tar
Sep 6, 2015 11:24 AM
philwarner
Sep 5, 2015 10:05 AM
