Replacing LNB6420BB with LJB6420BB
Old Nov 15, 2025 | 11:56 AM
schoeman's Avatar
Default Replacing LNB6420BB with LJB6420BB
The brake light / cruise control switch is very slightly different on the XJ8 vs. the XK8 x308 Jaguars. The XJ8 one is LNB6420BB, and they cost close to $200. The XK8 one is LJB6420, and can be found for $30 on ebay. A very slight modification is necessary. The LJB one is removed from the larger metal bracket, and would fit but for the fact that the slotted tab at the top is slightly too narrow. The solution is either to take the old one and grind out the slot in the plastic on the new one to be identical (about 1/16 inch wider -- see photo) or to replace the electronics in the old one with those in the new one (they easily slide out from the plastic box). Yes, the harness on the LJB is too long, but it is the same plug, and can be zip-tied out of the way.
Replace the $200 Brake Light Switch in a XJ8 with a $30 XK8 one
Old Nov 16, 2025 | 05:26 AM
Hooli's Avatar
I believe I've seen posts on here listing the part numbers to buy just the microswitches to rebuild the faulty one too.
Old Nov 18, 2025 | 02:57 AM
xjack's Avatar
Yes, replacing microswitch fixes the thing at minimum cost and job involved
Old Nov 18, 2025 | 10:15 AM
schoeman's Avatar
Default Soldering skills needed to replace the microswitches
Yes, the switch replacement works, but removing the through-hole 3-pin soldered in switches and replacing them requires some soldering skill and experience.
Old Nov 18, 2025 | 10:36 AM
Hooli's Avatar
That reminds me, I keep meaning to find the info & order the switches. I've got a broken one on the shelf to try & fix as a spare.
Old Nov 18, 2025 | 12:42 PM
xjack's Avatar
omron D2HW-A211D does the job
https://www.jaguarforums.com/forum/x...ch-fix-228803/
Old Nov 18, 2025 | 03:25 PM
Hooli's Avatar
Originally Posted by xjack
Excellent, thanks. I'll order a couple for one boring winter evening.
Old Nov 21, 2025 | 03:56 AM
Sean B's Avatar
Cool, got a 'no brake lights' - this should fix it, hoping it's not the SLMC!
Old Nov 21, 2025 | 04:05 AM
xjack's Avatar
Do you mean surface mount? No, they are through hole and quite large one so easy job
Flakster
Mar 14, 2026 08:59 AM
R3Wood
Jun 10, 2019 08:25 AM
Walt_C
Jul 13, 2017 06:35 PM
02jagstype
Feb 19, 2016 04:06 PM
tomtomterrific
Feb 7, 2016 08:21 PM
