Security Locking Control Module
Old Oct 1, 2016 | 07:27 AM
  #41
SpannersNK's Avatar
Hi Jag, thanks for the reply. Managed to sync the key fob, that works fine now. but still no start.
Had a look through the manual and it looks like all dash lights are as they should be when at pre ignition setting.
I'm pretty sure when I was pumping up a flat tyre with ignition on that I could hear the fuel pump ticking (I hadn't tried to start it at that point due to the old petrol) no ticking noise now.
Can any other owners confirm whether or not I should be able to hear the pump ticking continuously?
I've found reference to which fuses/relays to check in the boot so at least I can see if I've got voltage that far.
In terms of diagnostic software, does generic stuff work or is it like my '96 Range Rover very specific/bespoke to the model?
It's a lovely motor kept in great nick so be great to bring it back to life.
Old Oct 2, 2016 | 08:16 AM
  #42
JagV8's Avatar
I only know on my car that the pump just runs briefly at ignition on then stops.
Old Oct 3, 2016 | 02:45 AM
  #43
SpannersNK's Avatar
OK if that's the case then looks like my pump is probably dead as I get nothing and the fuses are ok. Will check for volts and relay function but reading around it seems fuel pump failure is relatively common.
Looks like getting the lines off of the bottom of the tank is the fun bit!
Will keep you posted as to progress and thanks again for the help.
Will.
Old Oct 4, 2016 | 09:42 AM
  #44
Jhartz's Avatar
First, try to reset the inertia switch. Sits inside the footwell on the right side. You may have bumped something while changing the tire. Switch kicks off to shut off fuel in case the car is in an accident. See owners manual.
Old Oct 4, 2016 | 10:02 AM
  #45
SpannersNK's Avatar
Hi Jim, I had read about that but thought it stopped the engine cranking, lowered the windows and stopped the central locking when tripped?
I guess anything is possible though with 90's electrics so next time I'm with the car I'll check it.
Old Jan 22, 2018 | 07:58 AM
  #46
MPDano's Avatar
Originally Posted by sparkenzap
The module is under the fuse block, nect to the battery , in the trunk. Whether you need to have it programmed for the key transponder, I know not.
This is good info. Thought that module was by the fuel filler but all I saw was the gas cap locking mechanism. Need to verify frequency before I buy a fob.
Thanks for this info.
Leo
Old Jan 22, 2018 | 10:06 AM
  #47
Nyoutftr's Avatar
I pulled that area all apart and could not feel it under the fuse box, do I have to remove the fuse box to even feel it.
This is a 2001 Vanden Plas
Thanks, help is needed
Old Jan 22, 2018 | 10:07 AM
  #48
Nyoutftr's Avatar
Is there a photo or diagram of this module in the truck?
Old Jan 23, 2018 | 09:48 AM
  #49
Jhartz's Avatar
You have to remove the fuze box. You can't miss it! Search for threads on bad rear brake lights to see pictures. Or check for posts from sparkenzap (wonder where he went?).
Old Aug 17, 2018 | 08:49 PM
  #50
Gabriel Galarza's Avatar
Default 1997 jaguar vdp
Do you know if it's possible to have these parts refurbished having a lot of trouble finding one
Old Feb 14, 2021 | 10:09 AM
  #51
Tim Giddens's Avatar
I look very well in the trunk and I cannot find my module. It's not under my fuse box or nowhere in my truck. Maybe ol boys are different. Do you have any other information on a picture of what yours look like? I seen them one on the internet, and I don't see that anywhere in the trunk unless my eyes are different. Thank you. Please help.
Old Feb 14, 2021 | 06:15 PM
  #52
Addicted2boost's Avatar
2 bolts on the left and 1 on the right need removed. The one at the top is the fob antenna that needs to be unscrewed after you get the 3 bolts removed that hold the entire assembly in place.
It says: SLM 315mhz
Old Feb 16, 2021 | 04:19 PM
  #53
Originally Posted by patfr275
the SLCM doesn't work on my XJ8 1998... The dealer ask for 800$ to change it... but I found some used ones on ebay for around 150$... how complicated is it to change it and where is it in the trunk on this 1998 model... I check around the gas fuel dispenser but didn't see it... ?? Then I'll have to reprogram my 2 remote control.
thank you
Two bodies have I have a 2003 XJ8 jaguar and on this vehicle? The security lock module is not under my fuse box. Is there anywhere else to look I look behind the seat under the seat back seat and took the roof down and no security lock Lottery. The reason why is because I burnt my key when I burn my trash, LOL. But yes, so I went to the junkyard and remove the key the key cylinder the computer and speed odometer, but I can't find the security lock module to change over do anyone have anywhere else in mind to look? I don't know what the difference is between my XJ8 in anyone else's but mine. Is it in the trunk of the car Thank you.
Bill MacKenzie
Apr 5, 2022 10:31 AM
03xk8
Feb 23, 2021 07:24 AM
arthurdaley
Jan 3, 2013 11:04 AM
Bolster
Aug 13, 2011 04:41 PM
micalsjag
Sep 22, 2010 06:15 PM
