So, if it’s not the fuse….
Old May 21, 2025 | 01:38 PM
larrygee's Avatar
Default So, if it’s not the fuse….
What would be my next step to trouble shoot a radio that will not power on? 2000 XJ8.
I checked all the fuses ( with a 12v tester ) identified in the owners manual with the word RADIO and they all were good.
I’m wondering if there is another fuse that affects the radio but isn’t identified as such in the manual description.
If not, what is the most likely culprit. It was working. I turned if off to have a conversation with someone and pressed the power button to turn it back on and…..nothing….
Yes, I have the code but, no power, therefore, no display.
Thanks in advance.
Old May 21, 2025 | 08:40 PM
Addicted2boost's Avatar
Did you spill any liquids in or around it? How long has it not been working?
Old May 21, 2025 | 09:00 PM
larrygee's Avatar
I did not spill anything, anywhere. It been working fine until I pressed the power off button temporarily. It’s been “not working” three days now as I’ve been testing fuses and relays. At least the fuses and relays that are described as “audio” or “amplifier” or any other language that would relate to sound…..
Old May 22, 2025 | 12:14 AM
Peter_of_Australia's Avatar
I am probably totally wrong here - but just on a hunch that I am not...:
I never removed a Jag-Radio before, hence I do not know, what it looks like from the back.
But I have worked a lot on my Sony Radio, which I removed from my old car in Germany and then put it into my van in Australia, and this radio does have its own fuse at the back of the unit - apart from any fuse the car itself may have...
Thus, if the Jaguar radio-unit itself also does have a fuse installed in its back, this might be a cause for your problem...
Old May 22, 2025 | 04:23 AM
larrygee's Avatar
Thank you for your reply. All “hunches” are welcome. Some hunches produce results, others just send you down the rabbit hole.You learn, regardless.
Having read many posts before asking here, I do not believe there is an inline fuse on the 2000 XJ8 radio. If anyone can definitively confirm this before I go pulling radios, I would appreciae it.
Old May 22, 2025 | 06:46 AM
Hooli's Avatar
I can't recall seeing a fuse on the back of the radio in mine.
I would however be tempted to pull the radio to check power is getting to it. There's two sources as far as I'm aware, the perm live for memory etc & a switched live. It'll need both to work.
Old May 22, 2025 | 09:01 AM
larrygee's Avatar
Thanks! At the moment I have no display which leads me to believe I have NO power.
It’s not likely a previously working, Device would suddenly lose power that's not fuse related. Was hoping to avoid pulling that radio out if someone could absolutely confirm that there is or is not an in-line fuse on a 2000 XJ8
Old May 22, 2025 | 05:13 PM
No inline or fuse slot in the back of the radio. At night, if you turn the running lights on, are the buttons lit up?
Old May 22, 2025 | 07:28 PM
larrygee's Avatar
Good question! I didn’t think to look. I will do that tonight and reply.
Thank you
Old May 22, 2025 | 08:58 PM
larrygee's Avatar
None of the buttons on the radio light up. The display died not light up.
For that matter, none of the buttons on the AC controls light up either UNLESS the function is selected, in which case there is a red led light that comes in to indicate “ON” position.
Old May 23, 2025 | 06:51 AM
Hooli's Avatar
Does the digital display for the temp have a working backlight? that's on the same circuit as the button backlights (all green cause of covers on the bulbs). If nothing works it's pointing to the whole circuit being dead which would probably help those who know these motors better than me to suggest a cause.
Old May 23, 2025 | 09:32 AM
larrygee's Avatar
The digital display that shows the temperature setting does have a working light.
None of the other adjustment buttons have a backlight. Only the little red light that comes on if selected.
Old May 23, 2025 | 09:46 AM
Hooli's Avatar
Failed bulbs in those then I'd say as it's all powered off the same multiplug, there's four from memory that cover all the buttons. Tiny things called Tsomething & 0.7w as far as I recall. I had to do one a while back as the right hand two buttons stopped illuminating.
Doesn't help with the radio though.
Old May 24, 2025 | 06:01 PM
larrygee's Avatar
Default SOLVED
First of all, thanks for all the suggestions!
Here’s the conclusion of the no power to radio saga.
What I didn’t share with you in the original post, (because I didn’t think it was relevant), was that I had bad front speakers.
They worked, but the surround foam was gone and the cone was rattling.
I took the car to an Audio shop this morning to have the speakers replaced.
The tech said that in many cars, including Jaguar, if the speakers fail or short out, the radio will automatically power off as a protection.
I was thinking, BS but, when I went to go pick up the car, after he had replaced the speakers the radio was, in fact, working! Go figure?
Old May 24, 2025 | 08:21 PM
I have never heard that before. No pun intended.
Old May 25, 2025 | 06:20 AM
larrygee's Avatar
Old May 25, 2025 | 07:09 AM
And I am speechless - also no pun intended...
Old May 25, 2025 | 08:31 AM
larrygee's Avatar
OK…. I sense the dad jokes coming….
Old May 25, 2025 | 11:18 AM
Hooli's Avatar
I'm struck dumb
Old May 25, 2025 | 02:08 PM
larrygee's Avatar
I'm struck dumb
Me too! If the Audio tech guy had not suggested that it said Known issue, I wouldn’t have believed it.
Either that or it’s a strange coincidence.
Either way, miraculously, the radio started working after replaced the speakers.
wrkey
Audio/Visual Electronics
May 11, 2024 04:56 AM
steve95xjs
Feb 6, 2023 05:51 PM
tmurena
Oct 9, 2017 12:11 AM
justininaz
Jun 10, 2011 05:59 PM
rljag2001
Apr 11, 2010 08:09 PM
