Steering column issue - yes I searched.
Old Sep 5, 2013 | 09:25 AM
Probesport's Avatar
Default Steering column issue - yes I searched.
My steering column problem is a little different from what I have read in a few posts here, but I am curious if the solution is the same (motor or reach cable)
My column goes in and out fine, goes down fine but to go up, I have to keep pressing up, let go, press up, etc. It only goes a small amount at a time up but all other directions work fine.
Where should I start?
Old Sep 5, 2013 | 12:37 PM
jjane1's Avatar
Interesting you say that, mine does the same thing only when going up '01 XJ8, lets see what others say,JJ
Old Sep 5, 2013 | 01:26 PM
motorcarman's Avatar
I probably replaced 50 or more for this fault when I worked at the dealer when these cars were new.
You can try to clean the potentiometer but if you want it to function you will need to replace it.
bob gauff
Old Sep 5, 2013 | 02:03 PM
Probesport's Avatar
So it's the pot most likely?
Old Sep 5, 2013 | 03:08 PM
Cabezagrande's Avatar
Could you explain a little further Bob? I'm having the exact same issue and would love to get it solved. I'm getting sick of the memory trying to cut my legs off because it can't bring the wheel up into the proper position.
Old Sep 5, 2013 | 09:03 PM
Replace the tilt motor assy.
bob gauff
Old Sep 5, 2013 | 09:19 PM
Probesport's Avatar
bob gauff
What is actually wrong? I would like to repair the fault and possibly improve any flaws versus just grab another unit and put it in.
Old Sep 5, 2013 | 09:26 PM
bob gauff
I just posted the problem.
bob gauff
Old Sep 6, 2013 | 07:57 AM
Probesport's Avatar
I guess i'm getting mixed signals here. So potentiometer, which isn't technically a potentiometer or entire tilt motor assembly, which seems excessive as the entire unit can't go bad beyond repair.
Old Sep 6, 2013 | 08:28 AM
The POT goes bad and there is NO replacement part available from Jaguar. (sensor NSS)
If you want to disassemble and repair then you can do that.
Jaguar sells the entire tilt motor assy.
bob gauff
Old Sep 6, 2013 | 08:49 AM
Probesport's Avatar
That's what I needed to know, rebuilding/redesigning the pot seems like the best bet to avoid failure again.
Old Sep 6, 2013 | 07:23 PM
Lear45's Avatar
You can find them on Ebay. Sometimes they are included when buying a clock spring.
$60 may get you a spare clock spring, turn signals, column controls .
rusty37
Apr 5, 2020 07:40 PM
PMKimpton
Aug 3, 2019 08:22 PM
sogood
Sep 15, 2015 07:35 AM
AL NZ
Sep 4, 2015 08:39 PM
laserguy
Sep 3, 2015 02:02 PM
