Tensioner question
Old Feb 12, 2018 | 01:14 PM
Doc_Schwartz's Avatar
Default Tensioner question
So I just wanted to ask since it's kind of been variable about the tensioners. I know that 2001 or 2002 and upwards models have pretty much all of the major problems fixed of this gen Jag, but are there any year models that have metal tensioners from the factory? Or all of them only aftermarket and replaced on existing engines?
Old Feb 12, 2018 | 07:01 PM
Sean B's Avatar
Engine build date is, I think, midnight August 13th 2001 - the USA market date the model year 1 year in advance, so all US '2002' models built after mid august should have the updated engine.
The date is stamped (backwards, eg 01-08-13-00-00) on the block, again from memory the 3rd rib back drivers side for LH -
But, this isn't set in stone, or the VIN numbers that go with those engines but it is a very good indicator that a car built after this date does have an all metal timing engine.
Old Feb 13, 2018 | 05:30 AM
JagV8's Avatar
Er... not "built after" as an engine may be built well before the car. Look at the actual engine, not the car's build date.
Old Feb 13, 2018 | 10:09 PM
cliveb's Avatar
can someone please tell me where exactly is the engine number is located on the motor. I've seen several vague diagrams, but I am still unable to locate the stamping.
Note:: I'm 64 and wear glasses.
thanks
Clive
Old Feb 13, 2018 | 10:20 PM
Coventrywood's Avatar
Thumbs up Open Pandora's Valve Cover
Doc_S.,
I have absolutely no "Jag Cred" to give anyone else advise. So I'm handing out some advice;
When in doubt, take a look. If an X308 is new to you, take a look.
If you or someone you trust has not yet opened the engine and inspected,
take a look.
Even if you have evidence the tensioners were done years ago, take a look.
Some early replacements appear to have been done with 1st gen. units. Whatever was in the stockroom drawer, I guess? (ask me how I know!)
You may find all is well. Which is much better than bouncing valves off of pistons.
Old Feb 13, 2018 | 11:17 PM
Z07Brandon's Avatar
Yeah, I have to agree. It's really not that hard to check what you have in the car. It will give you peace of mind as well, ask me how I know.
Old Feb 19, 2018 | 09:49 AM
XJDanny's Avatar
If you get a 2003 it’ll have the metal tensioners. My 2002 had the second generation plastic.
Old Feb 19, 2018 | 10:24 PM
Scotlad's Avatar
XJDanny, what month and year was your car built?
Old Feb 22, 2018 | 07:53 AM
XJDanny's Avatar
It was built in July 2001.
Old Feb 22, 2018 | 09:47 AM
JagV8's Avatar
That sounds like it cannot have the most up to date tensioners.
Old Feb 22, 2018 | 12:07 PM
motorcarman's Avatar
MAYBE someone installed the updated units. ALL my X308s have the metal body tensioners NOW!!!!!!!!! (they did NOT when I bought the cars)
bob
Old Feb 22, 2018 | 08:07 PM
XJDanny's Avatar
I had the metal tensioners installed. The car originally came with the second generation plastic tensioners. That’s why I said previously, if you want to ensure a car has metal tensioners, get a 2003.
rianbechtold
Apr 8, 2010 05:43 PM
troverman
Nov 7, 2008 07:05 AM
GordoCatCar
Aug 2, 2008 01:02 PM
Apr 5, 2008 08:54 PM
Mr T
Feb 19, 2008 08:26 AM
