Tips for remvoing stuck valve covers (cam covers)?
Old Aug 20, 2016 | 04:19 PM
OUScooby's Avatar
Default Tips for remvoing stuck valve covers (cam covers)?
I'm trying to get my valve covers off but it appears they are "glued" on by the the old gasket maker. I don't reall have room to get a blad in between to cut the gasket maker apart, and I'd also be wored about scoring the machined surface.
Any one else experience this? Got any tips?
Old Aug 20, 2016 | 07:16 PM
Addicted2boost's Avatar
Are you absolutely sure that all 14 bolts (12 parimeter 2 in center) are loose?? Those 2 center ones are a little bit hidden. If they are all loose but still not letting loose, I'd maybe tighten at least the 2 centers, loosely install the coils and run the engine to operating temp at idle to see if the heat releases them.
Old Aug 20, 2016 | 08:19 PM
OUScooby's Avatar
Yes got all 12 outer bolts, and the two in the center.
Can't idle the engine, no coolant, no oil and intake off and supercharger is halfway off.
Old Aug 20, 2016 | 08:30 PM
Johnny_B's Avatar
In that case, maybe careful use of a heat gun would do the same thing?
Old Aug 20, 2016 | 08:31 PM
I would use a type of putty knife or very flat and wide tool of some sort to carefully cavitate the gasket inward to try and break the silicone seal.
Old Aug 20, 2016 | 10:18 PM
plums's Avatar
The gaskets do not call for RTV except the little dabs in the front.
If you are sure that all the fasteners have been removed, a smart thump
sideways with the side of your fist usually does it.
You don't say how many miles or even what year, so it is pointless to
speculate about accumulated varnish.
Old Aug 20, 2016 | 10:43 PM
OUScooby's Avatar
Heat gun might work, I don't have one but I'll see about borrowing one.
Unfortunately with the intake manifold in the way there really isn't room to get a putty knife in there except at the very front of it.
Car is a 2000 XJR, 130k miles, sorry forgot to mention that, got a lot of other things to think about here, like my Jag potentially heading for the scrap heap.
Old Aug 20, 2016 | 11:41 PM
larney's Avatar
I gave a little loving nudge with a rubber mallet. They then came right off.
Old Aug 21, 2016 | 02:06 AM
Vector's Avatar
They should come off easily.
You have missed a fastener, find it before you break the cover trying to get it off.
Vector
Old Aug 21, 2016 | 01:48 PM
OUScooby's Avatar
Vector
I did, the two under that bracket holding the wiring in place. I removed the two small nuts holding the bracket on, but then didn't remove the two nuts underneath holding the cam cover on.
I feel silly, but its off now.
Old Aug 21, 2016 | 09:18 PM
Vector's Avatar
Glad you found them before you broke the covers.
Now I can tell you: I was going for the crowbar when I decided to take one more look for fasteners, found one I had missed and off it came, easy as can be.
Vector
Old Jan 11, 2019 | 09:45 AM
motorcarman's Avatar
wrong post
aholbro1
Mar 11, 2023 08:45 AM
kreyszig
Sep 30, 2016 11:22 PM
Peter36
Jul 6, 2016 08:52 PM
Atlastajag1
Jul 5, 2016 04:07 PM
webbeing
Jun 24, 2016 11:10 AM
