transmission oil pan needed or just filter
Old Jul 28, 2011 | 08:30 AM
vincent661983's Avatar
Default transmission oil pan needed or just filter
Dear fellow members
I am planning to do the transmission fluid change on 2000 XJR,I have seem some people change entire oil pan or it that ok to just replace with a new filter?
thank you
Old Jul 28, 2011 | 08:38 AM
motorcarman's Avatar
What secret Jaguar are you talking about??????????
bob gauff
Old Jul 28, 2011 | 08:57 AM
that is XJR
Old Jul 28, 2011 | 01:37 PM
You have a Mercedes W5A580 (AKA 722.6) 5 speed gearbox (5 forward and 2 reverse). The later Jaguars 2003> use the ZF6HP26 with the integral pan/filter assy.
You can change the filter and fluid and reuse your pan
bob gauff
Old Jul 28, 2011 | 06:13 PM
jimlombardi's Avatar
Default W5A580 Transmission drain & fill weblink
Hi
Here is the weblink to W5A580 Transmission drain & fill FAQ thread:
https://www.jaguarforums.com/forum/j...ons-faq-54992/
Go to post# 1 to download the PDF file.
Here is a PDF file on the W5A580 Transmission Fluid Pan removal & install (incudes Bolt Torque Specs).
2000 XJR Transmission Fluid Pan Gasket.pdf
Jim Lombardi
Old Jul 28, 2011 | 08:14 PM
Hi
Here is the Wa580 Transmission Fluid Pan Gasket and Transmission Fluid information I found on maxperformancecars forum thread (I updated the prices {retail and discount} and I provided the Supplier names and websites)
http://maxperformancecars.com/index.php/index.php?option=com_agora&task=topic&id=2794&Item id=159
Use Internet Explorer find function with "transmission fluid" as the search term, go to the 4th occurance of the search to find this posting.
Transmission Pan Gasket
Jaguar part number JLM20469
$32.80 $24.60 (JLM20469) Gaudin Jaguar parts
$14.50 $10.80 (1402710080) getmercedesparts.com
$14.50 $12.75 mercedesbenzgenuinep1.reachlocal.net
Transmission Fluid
Shell ATF 3403 - M115 (10 Liters)
Jaguar part number JLM20292
$37.70 $30.63 (Liter) (JLM20292) Gaudin Jaguar parts
$17.50 $13.13 (Liter) (001-989-68-03-10) getmercedesparts.com
$17.50 $15.75 /mercedesbenzgenuinep1.reachlocal.net
Note: These are Mercedes-Benz labeled bottles that are shipped/packaged to the Jag dealership in a Jag labeled box.
Jim Lombardi
Old Aug 1, 2011 | 04:43 PM
Hi,Jim
Do you have any ideas how many quarts I need for the change,I dont have the dipstick also?
Originally Posted by jimlombardi
Hi
Transmission Fluid
Jim Lombardi
Old Aug 2, 2011 | 12:06 AM
Hi
Looks like it takes 10 quarts to fill the transmission, torque converter and the cooling lines.
Here is a weblink to a thread on the XK8 & XKR forum about filling the MB WA580 transmission with fluid:
https://www.jaguarforums.com/forum/x...ush-easy-9760/
Go down to post# 7.
I thought it was 10 liters. It is still almost 10 quarts (9.46 quarts = 10 liters).
Jim Lombardi
Old Aug 2, 2011 | 04:23 AM
sparkenzap's Avatar
Ypu will not be able to change 10 qts in one cycle. I fyou use air to blow out the cooler you MIGHT get 6 or 7.
Old Aug 2, 2011 | 04:34 AM
plums's Avatar
Transmission Fluid
Just remembered, Ryder Fleet Products has this for $4.95/quart or so by mail order. Same Ryder as the truck people.
Old Aug 2, 2011 | 04:39 AM
plums's Avatar
Unless one is doing the fluid exchange at the cooler hose like the Mercedes boys. Then having at least a dozen quarts on hand is recommended.
xjrjag
Nov 27, 2025 09:16 AM
BrentGardner
29
Dec 16, 2024 12:13 AM
Torrid
Feb 15, 2020 08:03 AM
Rupesh
Mar 25, 2016 03:33 PM
divingmom
Aug 25, 2015 07:54 PM
