transmissions and fluid color
Old Aug 20, 2018 | 01:46 PM
Domesticated NOT Declawed's Avatar
Default transmissions and fluid color
I bought a new to me 2003 XJR. The transmission fluid looks green! Alldata tells me it is supposed to be Shell ATF 3403 M115. It doesn't mention color (or colour for us up here in Canada).
Anyone have any knowledge on GREEN ATF?
Prior owner had it at the dealer with P1601 code TCM computer / memory fault. The dealer looked at the connections and couldn't find any faults. It shifts great, no lights on since I cleared them. Anyone have any prior P1601 transmission experience and / or problems?
Old Aug 22, 2018 | 12:23 AM
No one has any input into transmission fluid colour or color?
Old Aug 22, 2018 | 05:46 AM
RJ237's Avatar
That might be Pentosin.
Old Aug 22, 2018 | 12:48 PM
Is Pentosin green?
Old Aug 22, 2018 | 03:47 PM
RJ237's Avatar
Yes, that's why I mentioned it.
Old Aug 22, 2018 | 03:52 PM
motorcarman's Avatar
The Mercedes-Benz 5G-Tronic (also called 722.6 or NAG1 (WA580)) is used in the 4.0 SC X308.
Many car manufacturers used the gearbox, Mercedes, Chrysler, Jaguar etc.
I have always seen the appropriate fluid color as RED.
Maybe someone used a fluid that meets the proper specs but is green??
IDK
bob
Old Aug 22, 2018 | 06:01 PM
Hmmm... I went to the Pentosin website:
http://www.pentosin.net/specsheets/Pentosin_ATF1.pdf
It describes it as amber and clear
Pentosin - Transmission Fluid
My previous XJR had red.
Regardless, I’m going to service it sooner than later.
If anyone else has green transmission fluid in their XJ, I’d love to hear from you!!!
Old Aug 22, 2018 | 06:16 PM
Sounds like Castrol Transmax Z ATF is green.
I answered my own question!
still like to hear from others who have used this and can verify it’s color or colour!
Old Aug 22, 2018 | 08:36 PM
Bcrary3's Avatar
IDK
bob
If I am not mistaken this box uses typical ATF4? Which should typically be red?
I know others use "gold" coloured ZF fluid, but does anyone other than ZF use gold?
EDIT:
TransMax may be green in colour (no confirmation). Apparently CVT fluid is GEEN in hue. Trans could have mistakenly been filled with CVT Fluid.
Personally if it were me, I'd drain, get a new filter and replace with new fluid that you know what it is.
Old Aug 23, 2018 | 02:03 AM
Jeroen's Avatar
Just curious, how did you find out it is green? There is no dip stick? Did you get one or did you open up the tranny?
Jeroen
Old Aug 23, 2018 | 08:13 AM
Jeroen
True that there is no dipstick supplied with the car but it is available as a 'tool' to check the level.
This is a MERCEDES gearbox we are discussing, NOT the ZF 5HP24.
bob
Old Aug 23, 2018 | 11:25 AM
I have a ‘universal’ dipstick I bought online for cars that don’t have a dipstick.
I have seen CVT fluid which is kind of green.
I hope that someone on here has opened a bottle of the Castrol transmax Z and can verify its colour! I will change it sooner than later.
jazzwineman
Mar 8, 2017 09:05 AM
sg18438
Feb 22, 2017 09:35 PM
Sinister 1
Jul 3, 2010 11:11 AM
pszikszai
Jul 21, 2008 09:57 AM
hankycbr
Oct 9, 2007 04:21 AM
