Ultra High performance tires?
Old May 23, 2011 | 04:45 PM
Thundercat's Avatar
Default Ultra High performance tires?
Hey Gents,
looking at a new set of shoes for the Jag. The size thats on there now is 255 45 18. I'm noticing that most ultra high performance/track tires only come in 255 35 18. What do you think about a shorter sidewall? Could I fit anything wider like 265's on there?
These ones are 255 40 18. liking the the Yokohama advan's
Tire Search Results
Any feedback or advice always appreciated. Thanks!
Old May 23, 2011 | 04:48 PM
Thundercat's Avatar
PROXES R1R Extreme Performance Summer Tires | Toyo Tires
Or these but they are only available in a 255 35.
Old May 23, 2011 | 04:52 PM
Thundercat's Avatar
after this i'll shut up i promise. Hankook Rs-3 and Dunlop Durezza Star Spec. This car is not a daily driver btw. Cheers!
Old May 23, 2011 | 06:09 PM
SteveM's Avatar
Well the stock size is supposed to be 255/40/18 so you can start from there.
Old May 23, 2011 | 06:31 PM
plums's Avatar
As mentioned by SteveM, that is oversize.
But, how are you liking them?
They fill the wheel well quite nicely as they are slightly larger in diameter.
Toyo's are, and have a reputation for being noisy.
Old May 23, 2011 | 07:34 PM
burmaz's Avatar
Hey Gents,
Tire Search Results
Do your tires rub at all?
I have 245/45/18 Contiental Contiextreme Contacts on my 2000 VDP and they rub just a little if I turn the wheel to the extreme left or right and run over a bump. It almost never happens though.
Old May 23, 2011 | 08:14 PM
test point's Avatar
Unless you are getting paid to drive your car . . . fast . . . you are wasting your money on super high performance tires.
Look at some of the ratings and customer feedback at TireRack for far better investment of your hard earned bucks.
Old May 23, 2011 | 08:51 PM
Thundercat's Avatar
Thanks. you guys are champs. no rubbing. can i put a 265 on there? I would like to put some no BS tires on this thing as I drive only in the summer and the car is EXTREMELY powerful. I drive it MAYBE 5k per year. Lets consider this a price is no object kinda thing.
Old May 23, 2011 | 09:01 PM
burmaz's Avatar
I agree. Contiental Contiextremeconatcts are decent ultrahighperformance all-season tires. They have pretty good reviews and are actually very cheap. They give very good grip for wet and dry roads. However, they wear out pretty fast and have flaws too.
Make sure you get some good tires though. My car came with Pirelli P6 tires that were absolute CRAP. They had weak wet and dry traction at the limit.
It sounds like you are a performance driver? The prob with the Contientals is that the sidewalls are soft and can lead to rim damage on rough roads. Also, the tires are very quiet when they skid which can be a problem if you drive on a track and etc. They can give a false sense of having more traction than you really have. The Pirellis scream when they skid. Look for tires that scream when skidding if you are a track driver. I have a long wheel base XJ that is designed to understeer and plow in the corners. The sound of skidding to indicate understeer is pretty important when driving my car aggressively.
Its great to see that you are upgrading your car. Too few people upgrade their XJRs.
Has anyone been able to powerslide in a controlled manner in a XJ? I know that an open diff makes this pretty difficult. Its pretty hard to control my VDP in a powerslide. Its also close to impossible to get a VDP to even oversteer on a dry road without the throttle (actually I have never been able to do this at all).
Old May 23, 2011 | 09:06 PM
SteveM's Avatar
I'm assuming you have a 8" wide wheels. 265's are too wide for 8". Tire Rack has the recommended wheel widths for each tire size in the specs chart.
Old May 23, 2011 | 09:17 PM
Doug's Avatar
Does this go as far as buying new tires every two years?....'cuz that's probably what you'll be looking at with ultra high performance summer tires.
You probably know that already but I had to throw it in :-)
Old May 23, 2011 | 09:19 PM
burmaz's Avatar
Do you have a limited slip diff? The rear suspension on the XJ is primitive IMHO and gives too much wheel hop, well at least on my car. In comparison to the multilink rear suspension on the newer XJ, the X308 suspension does not keep the wheel perpendicular to the road as well when driving over bumps or through the corners. The rear doesn't slide at all on my car, but the throttle can break it loose pretty easily, and this is only a non s/c car.
Old May 23, 2011 | 09:26 PM
plums's Avatar
In fact, even 255/40 is too wide for a 8 inch rim according to the vendor info shown at tirerack. 245/40 just squeaks in, and a 235 is a more reasonable fit for 8 inches. A 235/45 has almost the same revolutions per mile as a 255/40.
Old May 23, 2011 | 09:32 PM
Thundercat's Avatar
255 40 it is. Thanks gents. Cheers!
plums's Avatar
hannnh?
Old May 23, 2011 | 09:58 PM
burmaz's Avatar
Originally Posted by plumsauce
hannnh?
Old May 24, 2011 | 04:43 AM
Sean B's Avatar
I run 255/35/19's being an XJR100 it has the Montreal wheels. The car loves good tyres.
I've used Michelin Pilot Sport 2's to good effect, excellent dry tire.
I'm now using Bridgestone Potenza RE50's, and these I find are even better in the dry.
(I don't use the car in rain)
I'd recommend these.
Whatever, they'll have to be Y96 rated, extra load. Because of the size and speed of your car, use nothing less. Period.
James007
Oct 3, 2015 03:29 PM
Horus
Sep 18, 2015 05:39 AM
johndahlheimer
Sep 16, 2015 05:44 PM
KarimPA
Sep 12, 2015 08:15 AM
James007
Sep 6, 2015 06:47 PM
