what kind of spark plugs does my 98 xjr use?
Old Feb 26, 2012 | 03:35 PM
jaguars4r's Avatar
Default what kind of spark plugs does my 98 xjr use?
I need plugs for my 98 xjr and it had champions on them, are those the right plugs? Not trying to spend $10ea plug at the dealer either, perf. Somthing at napa, autozone..etc
Old Feb 26, 2012 | 04:53 PM
adam699's Avatar
1998 JAGUAR XJR Spark Plug
Old Feb 26, 2012 | 06:29 PM
JaguarXJR02's Avatar
if you go to advance auto or some place like that you can just tell them what car you have and they can pull up the list of potential plugs
good luck
Old Feb 26, 2012 | 08:01 PM
Gus's Avatar
Gus
This link http://jagrepair.com/images/AutoRepa...sb_09_2003.pdf on page 17 will give you the Jaguar nomenclature use it to cross over to a quality plug from your local store.
Old Feb 26, 2012 | 10:28 PM
jaguars4r's Avatar
Well i dont just want any plugs, what plugs do yu guys use? Are those champions right ones?
Old Feb 26, 2012 | 11:08 PM
Murat's Avatar
SORRY, I Accidentally posted the plugs for an XJ8 below, but I will leave it as reference for the N/A owners. The XJR is Jaguar OEM NGK Laser Platinum PFR6G-13E. If you want Laser Iridium It should be the same as the XJ8 part number but with a 6 in place of the 5.
XJ8 Plugs
The plug is NGK Laser Platinum PFR5G-13E which has a platinum tip and laser welded platinum in the ground electrode. costs $13/ plug at Advance Auto Parts, but good to 100k.
Interestingly, the 4.2 x350 NGK Laser Iridium plug cross references to the x308 4.0 laser platinum plug. That is the one that I changed over to because it costs the same yet it has an iridium tip and a laser welded platinum ground electrode.
I'm sure if the iridium plugs were around back then, they would have used it as well.
The NGK grades in order of preference are:
Laser Iridium $13 IFR5N10
Laser Platinum $13 (Jaguar OEM) PFR5G-13E
Iridium $7 BKR5EIX-11
Old Feb 26, 2012 | 11:25 PM
jaguars4r's Avatar
I need something cheaper, its more of a test for my car to try to figure out a problem, so anything cheaper that I can get away with?
Old Feb 27, 2012 | 07:42 AM
Gus's Avatar
Gus
I have been using Bosch plugs in all my Jags but my cars are not supercharged.
dsnyder586
Dec 29, 2024 07:39 PM
cissdm
May 3, 2016 06:02 AM
mrplow58
Sep 9, 2015 11:27 AM
MrMellor
Sep 7, 2015 10:22 AM
Bowman
Sep 3, 2015 03:17 PM
