will Austin Marin DB7 calipers fit XJR
Old Apr 27, 2015 | 02:11 PM
vincent661983's Avatar
Default will Austin Marin DB7 calipers fit XJR
my logic is DB7 shares DNA with XKR and XKR shares with XJR
wheel clearance is not my concern since I am already running 20 inch rims
Old Apr 27, 2015 | 02:40 PM
andrew lowe's Avatar
My logic is.... Jaguar parts are expensive enough to start with.
Why would you want to purchase parts for a bespoke, hand made sports/ GT car that sold for a premium of about 50-60% above an XK8 ?
Old Apr 27, 2015 | 03:24 PM
Mark SF's Avatar
Erm, no. A DB7 shares DNA with the previous generation, the XJS, which in turn shares with the older XJ6s. XJ8 has different front and rear suspension.
Old Apr 27, 2015 | 03:30 PM
or X350 brembo, I happen to be able to obtain set of calipers, rotors, wheel hub with ABS sensor
Old Apr 27, 2015 | 03:58 PM
Am pretty sure the X350 uses a different PCD to the X308.
do not know if the X350 ABS sensors will work with the X308 ABS.
Richard_gib
Sep 12, 2015 07:08 PM
metalmarty
Sep 11, 2015 07:05 AM
philwarner
Sep 6, 2015 11:10 PM
JagLove86
Sep 6, 2015 10:36 PM
philwarner
Sep 5, 2015 10:05 AM
